Thanks. The fact that db_post_events uses the original pointer as identifier explains the necessity to keep it intact. That was what I was missing.
I understand your second remark to refer to an API change, where we require the field index to be passed as a parameter to db_post_events instead of the pointer? I think everyone will agree that this is the "right thing" to do, but it would indeed be quite painful, since it affects all record types, not only those in base. The alternative you mention is not very convincing; if we shy away from the pain of an API change we can as well keep things as they are. But we really should add a comments in the code to explain this subtlety.
https://code.launchpad.net/~bfrk/epics-base/+git/epics-base/+merge/381308
Your team EPICS Core Developers is requested to review the proposed merge of ~bfrk/epics-base:zero-size-array-request into epics-base:7.0.
- [Merge] ~bfrk/epics-base:zero-size-array-request into epics-base:7.0 Ben Franksen via Core-talk
Re: [Merge] ~bfrk/epics-base:zero-size-array-request into epics-base:7.0 mdavidsaver via Core-talk
debugger w/ reverse execution Michael Davidsaver via Core-talk
<2020>
2025
2026
Re: [Merge] ~bfrk/epics-base:zero-size-array-request into epics-base:7.0 Ben Franksen via Core-talk
<2020>
2025
2026
