Hi Andrew,
Am 30.03.20 um 06:08 schrieb Johnson, Andrew N.:
> I’m also thinking of a put filter where you can give individual array
> index values to be written to, so to create a filter that only
> overwrites specific elements of the target array you might want to
> specify a channel filter as
> pvname.{“subset”:[0,1,2,4,6,10,12,16,18]}
> The idea is that there might not be an arithmetic slice/stride
> pattern to the index values.
I have implemented this proposal, albeit with plain bracket notation,
that is you specify "PV[0,1,2,4,6,10,12,16,18]" directly. It is just
another form of address modifier, alongside the "PV[s:i:e]" notation.
The code is probably buggy since I haven't done serious testing yet,
just some experiments with caput and a simple soft IOC. If you are
interested, this is the latest commit on my work branch:
https://code.launchpad.net/~bfrk/epics-base/+git/epics-base/+ref/work
I have also updated all my merge proposals with a forced push to get rid
of unwanted commits and to avoid conflicts with 7.0.
Cheers
Ben
signature.asc
Description: OpenPGP digital signature
- Re: double filters Ben Franksen via Core-talk
- double filters Ben Franksen via Core-talk
- Re: double filters Johnson, Andrew N. via Core-talk
Build completed: EPICS Base base-3.15-577 AppVeyor via Core-talk
<2020>
2025
2026
<2020>
2025
2026
