2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Bug 1861612] Re: callbackRequestDelay not waiting for 1/60 sec on vxWorks
From: Ben Franksen via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sun, 12 Apr 2020 10:51:56 -0000
I didn't mean to dispute your anaysis. I think it is correct and I
understood it exactly in the way suggested by your diagram.
> The short answer is the both Andrew and I have tried +=1 and it
doesn't work.
It cannot work if you convert using trunc, which is the default "cast"
conversion between float and int.
> In this case the float to int conversion floor(D/T)==0. So +=1 gives a
delay of 1. This will wait until the next tick (time A) which is almost
zero.
I was proposing to use ceil. This will result in 1, except if the input
is exactly 0.0.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1861612
Title:
Status in EPICS Base:
  Triaged
Bug description:
  The problem is documented in this tech-talk thread:
  https://epics.anl.gov/tech-talk/2020/msg00308.php
  In 7.0.3.1, but not in 7.0.3, callbackRequestDelay(1/60) results in
  100% CPU time, most of the time in cbHigh.
  This happens on vxWorks 6.9.4.1 and was first seen with the scaler
  record with multiple types of scaler hardware and device support.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1861612/+subscriptions
[Bug 1861612] [NEW] callbackRequestDelay not waiting for 1/60 sec on vxWorks rivers via Core-talk
[Bug 1861612] Re: callbackRequestDelay not waiting for 1/60 sec on vxWorks mdavidsaver via Core-talk
Prev: [Bug 1861612] Re: callbackRequestDelay not waiting for 1/60 sec on vxWorks mdavidsaver via Core-talk
Next: [Bug 1861612] Re: callbackRequestDelay not waiting for 1/60 sec on vxWorks mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 12 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
