2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mp+382303 at code.launchpad.net
Date: Thu, 16 Apr 2020 07:18:58 -0000
Hi Andrew,
I had already started on an .indent.pro file, but so far found no setting that matches the majority of EPICS base coding styles (or let's better say: habits). But I am still trying...
I can also do the same for the 3.15 branch, so that the two look the same. I hope git is ok with two changes that do the same thing and then merging them?
And I was hoping not to limit the fixes on the modules/ca tree only. Let me check if I forgot something... But I have to admid, the ca tree was the worst.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/382303
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Jenkins build is still unstable: epics-7.0 » linux32 #216 APS Jenkins via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 16 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
