2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Build completed: EPICS Base base-3.15-587
From: AppVeyor via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 17 Apr 2020 15:16:46 +0000
Build EPICS Base base-3.15-587 completed
Commit 841effe9ee by Andrew Johnson on 4/16/2020 10:14 PM:
epicsMessageQueueTest: Shorten the 1R4S tests
Configure your notification preferences
Prev: AW: Problem compiling EPICS 7 commit 85d1982 when INSTALL_LOCATION is set Zimoch Dirk (PSI) via Core-talk
Next: AW: Problem compiling EPICS 7 commit 85d1982 when INSTALL_LOCATION is set Zimoch Dirk (PSI) via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Problem compiling EPICS 7 commit 85d1982 when INSTALL_LOCATION is set Johnson, Andrew N. via Core-talk
Next: Build failed: epics-base base-3.15-14 AppVeyor via Core-talk
ANJ, 18 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
