2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: IOC shell usage messages
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Mon, 27 Apr 2020 17:07:09 +0000
On Apr 24, 2020, at 10:52 PM, Michael Davidsaver via Core-talk <core-talk at aps.anl.gov> wrote:
I think this is so plainly and obviously useful that I've gone ahead
and pushed it to the 7.0 branch.
https://github.com/epics-base/epics-base/commit/ce4fb6085ffccd2ad0c29191d221c55341a485a6
Looks good.
Most of the built-in commands are actually described in the AppDevGuide reasonably well, although the commands are usually embedded in the chapters describing their associated subsystem, and we have probably added functionality to some commands without documenting it there. In most cases the wording there would probably have been too verbose for this, but the docs might describe features that could be mentioned in the help text.
And hey, who knew that "help" supported wildcard matching?
Anyone who has read the Release Notes for Base-3.14.7 (admittedly rather terse), or the AppDevGuide documentation chapter on iocsh perhaps? This is from chapter 18 of the 3.14 Guide; the wildcard feature was added in 2004:
help [command ...] Display synopsis of specified commands. Wild-card matching is applied so ‘help db*’ displays a synopsis of all commands beginning with the letters ‘db’. With no arguments display a list of all commands.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: IOC shell usage messages Michael Davidsaver via Core-talk
Prev: Re: Base CI tests on MacOS failing Michael Davidsaver via Core-talk
Next: Re: [Merge] ~johill-lanl/epics-base/+git/epics-base:timer-queue-fix into epics-base:7.0 Martin Konrad via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: IOC shell usage messages Michael Davidsaver via Core-talk
Next: Re: IOC shell usage messages Michael Davidsaver via Core-talk
ANJ, 27 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
