2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1812084] Re: Build failure on RTEMS 4.10.2
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Wed, 13 May 2020 04:40:17 -0000
> unfortunately it doesn't look like there's an easy way to detect the
change at compile-time
In fact there is.  This (internal) API change appears on the RTEMS 4.10
branch after the (latest) 4.10.2 release.
I've been testing the attached patch for the past week or so.
** Patch added: "0001-RTEMS-osdThread-real_priority.patch"
   https://bugs.launchpad.net/epics-base/+bug/1812084/+attachment/5370738/+files/0001-RTEMS-osdThread-real_priority.patch
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1812084
Title:
Status in EPICS Base:
  Confirmed
Status in EPICS Base 3.15 series:
  Confirmed
Status in EPICS Base 7.0 series:
  Confirmed
Bug description:
  Michael Westfall reported:
  When compiling base R3.14.12.7 for RTEMS 4.10.2, I get the following
  error:
  /gem_swdev1/targetOS/RTEMS/rtems-4.10/bin/powerpc-rtems4.10-gcc --pipe -B/gem_swdev1/targetOS/RTEMS/rtems-4.10/powerpc-rtems4.10/beatnik/lib/ -specs bsp_specs -qrtems   -fasm -c   -mcpu=7400 -D__ppc_generic                   -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL -DHAVE_MOTLOAD -DRTEMS_NETWORK_CONFIG_MBUF_SPACE=2048 -DRTEMS_NETWORK_CONFIG_CLUSTER_SPACE=5120     -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/RTEMS -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I/gem_swdev1/epics/R3.14.12.7/base/include/os/RTEMS -I/gem_swdev1/epics/R3.14.12.7/base/include         ../../../src/libCom/osi/os/RTEMS/osdThread.c
  ../../../src/libCom/osi/os/RTEMS/osdThread.c: In function 'showInternalTaskInfo':
  ../../../src/libCom/osi/os/RTEMS/osdThread.c:617: error: 'Thread_Control' has no member named 'real_priority'
  ../../../src/libCom/osi/os/RTEMS/osdThread.c:624: error: 'Thread_Control' has no member named 'current_priority'
  ../../../src/libCom/osi/os/RTEMS/osdThread.c:624: error: 'Thread_Control' has no member named 'real_priority'
  ../../../src/libCom/osi/os/RTEMS/osdThread.c:625: error: 'Thread_Control' has no member named 'current_priority'
  ../../../src/libCom/osi/os/RTEMS/osdThread.c:627: error: 'Thread_Control' has no member named 'real_priority'
  ../../../src/libCom/osi/os/RTEMS/osdThread.c:627: error: 'Thread_Control' has no member named 'current_priority'
  make[3]: *** [osdThread.o] Error 1
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1812084/+subscriptions
Prev: [Bug 1812084] Re: Build failure on RTEMS 4.10.2 Heinz Junkes via Core-talk
Next: [Bug 1812084] Re: Build failure on RTEMS 4.10.2 mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 12 May 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
