See <https://jenkins.aps.anl.gov/job/epics-base-7.0-win64/118/display/redirect?page=changes>
Changes:
[Ralph Lange] doc: add description of improved simulation mode
[Michael Davidsaver] fix epicsTempFile in antelope+e_flex
[Michael Davidsaver] CleanupWhitespace
[Ralph Lange] doc: update simulation parameters sections in dbds
[Michael Davidsaver] Remove ANSI-C OS prototypes from flexdef.h
[Michael Davidsaver] Add a getter function for field_type
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on win64-2 (windows-x64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-7.0-win64/ws/>
No credentials specified
> C:/Program Files/Git/cmd/git.exe rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> C:/Program Files/Git/cmd/git.exe config remote.origin.url https://git.launchpad.net/epics-base # timeout=10
Using shallow fetch with depth 5
Fetching upstream changes from https://git.launchpad.net/epics-base
> C:/Program Files/Git/cmd/git.exe --version # timeout=10
Setting http proxy: webproxy1.anl.gov:9091
> C:/Program Files/Git/cmd/git.exe fetch --no-tags --force --progress --depth=5 -- https://git.launchpad.net/epics-base +refs/heads/7.0:refs/remotes/origin/7.0 # timeout=10
> C:/Program Files/Git/cmd/git.exe rev-parse "refs/remotes/origin/7.0^{commit}" # timeout=10
> C:/Program Files/Git/cmd/git.exe rev-parse "refs/remotes/origin/refs/heads/7.0^{commit}" # timeout=10
Checking out Revision 0f88c67473d246be4f721f6f058289eaffcd75b4 (refs/remotes/origin/7.0)
> C:/Program Files/Git/cmd/git.exe config core.sparsecheckout # timeout=10
> C:/Program Files/Git/cmd/git.exe checkout -f 0f88c67473d246be4f721f6f058289eaffcd75b4 # timeout=10
Commit message: "Add a getter function for field_type"
> C:/Program Files/Git/cmd/git.exe rev-list --no-walk 4b848ef344f32f8c0cfe08d11171876958e79449 # timeout=10
Cleaning workspace
> C:/Program Files/Git/cmd/git.exe rev-parse --verify HEAD # timeout=10
Resetting working tree
> C:/Program Files/Git/cmd/git.exe reset --hard # timeout=10
> C:/Program Files/Git/cmd/git.exe clean -fdx # timeout=10
[epics-base-7.0-win64] $ cmd /c call C:\Users\jenkins\AppData\Local\Temp\jenkins3433285053087507228.bat
C:\jenkins\win64-2\workspace\epics-base-7.0-win64>make -j4 -O --no-print-directory
'make' is not recognized as an internal or external command,
operable program or batch file.
C:\jenkins\win64-2\workspace\epics-base-7.0-win64>exit 9009
Build step 'Execute Windows batch command' marked build as failure
[MSBuild] Skipping execution of recorder since overall result is 'FAILURE'
- Jenkins build is back to normal : epics-base-7.0-win64 #119 APS Jenkins via Core-talk
Jenkins build is back to stable : epics-7.0 » linux32 #222 APS Jenkins via Core-talk
Build failed: epics-base base-doc-sim-mode-331 AppVeyor via Core-talk
<2020>
2025
2026
Build failed: epics-base base-7.0-505 AppVeyor via Core-talk
<2020>
2025
2026
