2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: AW: AW: EPICS 7 and VxWorks 6.9 for PPC604?
From: "Zimoch Dirk \(PSI\) via Core-talk" <core-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: "'core-talk at aps.anl.gov'" <core-talk at aps.anl.gov>
Date: Wed, 3 Jun 2020 16:53:01 +0000
The full options are:
/afs/psi.ch/project/vxworks/VxWorks6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc       -isystem /afs/psi.ch/project/vxworks/VxWorks6.9/vxworks-6.9/target/h   -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall    -fno-builtin -fno-strict-aliasing  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I/usr/local/epics/base-7.0.4.1/include/compiler/gcc -I/usr/local/epics/base-7.0.4.1/include/os/vxWorks -I/usr/local/epics/base-7.0.4.1/include        -I/afs/psi.ch/project/vxworks/VxWorks6.9/vxworks-6.9/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.9/vxworks-6.9/target/h/wrn/coreip -c ../fdmgr/fdmgr.cpp
> -----Ursprüngliche Nachricht-----
> Von: Michael Davidsaver <mdavidsaver at gmail.com>
> Gesendet: Mittwoch, 3. Juni 2020 18:39
> An: Zimoch Dirk (PSI) <dirk.zimoch at psi.ch>
> Cc: 'core-talk at aps.anl.gov' <core-talk at aps.anl.gov>
> Betreff: Re: AW: EPICS 7 and VxWorks 6.9 for PPC604?
> I should have also asked.  Can you show all of the arguments being passed to
> gcc?
> >> It's gcc 4.3.3.
> RTEMS 4.9.6 has gcc 4.3.2 which works for the PPC targets I'm aware of.
> Both soft and hard float.
> On 6/3/20 8:31 AM, Zimoch Dirk (PSI) wrote:
> > I will try the selective -fno-inline ...
> >> Von: Zimoch Dirk (PSI)
> >> Gesendet: Mittwoch, 3. Juni 2020 17:30
> >> An: 'Michael Davidsaver' <mdavidsaver at gmail.com>; 'core-
> >> Betreff: AW: EPICS 7 and VxWorks 6.9 for PPC604?
> >> It's gcc 4.3.3.
> >> Using -O0 (as used to fix bug 1702298) in helps for fdmgr.cpp but not for
> >> typeCast.h.
> >>> Gesendet: Mittwoch, 3. Juni 2020 17:13
> >>> An: Zimoch Dirk (PSI) <dirk.zimoch at psi.ch>; 'core-talk at aps.anl.gov' <core-
> >>> Betreff: Re: EPICS 7 and VxWorks 6.9 for PPC604?
> >>> For those of us who aren't so familiar with vxworks, which GCC version(s)
> are
> >>> involved.
> >>> You may remember https://bugs.launchpad.net/epics-base/+bug/1702298
> >>> On 6/3/20 8:04 AM, Zimoch Dirk (PSI) via Core-talk wrote:
> >>>> Has anyone already compiled EPICS 7 for VxWorks 6.9 for PPC604?
> >>>> I have problems:
> >>>> With -O2 it fails here:
> >>>> ../fdmgr/fdmgr.cpp: In member function 'virtual
> >>> epicsTimerNotify::expireStatus timerForOldFdmgr::expire(const
> epicsTime&)':
> >>>> ../fdmgr/fdmgr.cpp:152: error: unable to find a register to spill in class
> >>> 'FLOAT_REGS'
> >>>> ../fdmgr/fdmgr.cpp:152: error: this is the insn:
> >>>> (insn:HI 16 15 17 2 ../fdmgr/fdmgr.cpp:151 (set (reg:DF 126 [
> D.11913.delay
> >>>>         (mem/s/j/c:DF (plus:SI (reg/f:SI 113 sfp)
> >>>>                 (const_int 8 [0x8])) [0 D.11913.delay+0 S8 A64])) 336
> >>> {*movdf_hardfloat32} (expr_list:REG_EQUIV (mem/s/j/c:DF (plus:SI (reg/f:SI
> >> 113
> >>> sfp)
> >>>>         (nil)))
> >>>> ../fdmgr/fdmgr.cpp:152: confused by earlier errors, bailing out
> >>>> With -O1 (or lower) it comliles the above but then fails here:
> >>>> ../../src/misc/pv/typeCast.h: In function
> >> 'void<unnamed>::castVTyped(size_t,
> >>> void*, const void*) [with TO = std::basic_string<char, std::char_traits<char>,
> >>> std::allocator<char> >, FROM = float]':
> >>>> ../../src/misc/pv/typeCast.h:195: sorry, unimplemented: inlining failed in
> call
> >>> to 'TO epics::pvData::castUnsafe(const FROM&) [with TO =
> >>> std::basic_string<char, std::char_traits<char>, std::allocator<char> >, FROM
> >>> float]': recursive inlining
> >>>> ../../src/misc/typeCast.cpp:38: sorry, unimplemented: called from here
> >>>> At least the compiler is "sorry".  I feel much better.
> >>>> BTW: VxWorks 6.7 has no such problems.
> >>>> Dirk
EPICS 7 and VxWorks 6.9 for PPC604? Zimoch Dirk (PSI) via Core-talk
Re: EPICS 7 and VxWorks 6.9 for PPC604? Michael Davidsaver via Core-talk
AW: EPICS 7 and VxWorks 6.9 for PPC604? Zimoch Dirk (PSI) via Core-talk
Re: AW: EPICS 7 and VxWorks 6.9 for PPC604? Michael Davidsaver via Core-talk
Prev: Re: AW: EPICS 7 and VxWorks 6.9 for PPC604? Michael Davidsaver via Core-talk
Next: Re: EPICS 7 and VxWorks 6.9 for PPC604? Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: Re: AW: EPICS 7 and VxWorks 6.9 for PPC604? Michael Davidsaver via Core-talk
ANJ, 03 Jun 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
