2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1882520] Re: Constant arrary input links of size 1 don't work
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 08 Jun 2020 16:19:19 -0000
** Merge proposal linked:
   https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/385269
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1882520
Title:
Status in EPICS Base:
  In Progress
Bug description:
  Constant input links in array form with 1 element don't work and
  return an empty array.
  Example:
  field (INP, [42])
  As soon as a comma is present, it works:
  field (INP, [42,])
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1882520/+subscriptions
[Bug 1882520] [NEW] Constant arrary input links of size 1 don't work Dirk Zimoch via Core-talk
Prev: [Bug 1881563] Re: Empty arrays have undefined behavior Andrew Johnson via Core-talk
Next: [Bug 1882520] Re: Constant arrary input links of size 1 don't work Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: [Bug 1882520] Re: Constant arrary input links of size 1 don't work Andrew Johnson via Core-talk
ANJ, 08 Jun 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
