2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: epics-base-7.0-win64s-test - Build # 196 - Unstable!
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Wed, 15 Jul 2020 06:36:31 -0500 (CDT)
Job: Test the 7.0 branch of Base for windows-x64-static
Build URL: https://jenkins.aps.anl.gov/job/epics-base-7.0-win64s-test/196/
This job built successfully, but has failing tests.
Test results:
C:\jenkins\win64-2\workspace\epics-base-7.0-win64>make -s test-results   || exit /B 255
C:/jenkins/win64-2/workspace/epics-base-7.0-win64/test/tools/O.windows-x64-static
Snippets.tap .. ok
All tests successful.
Files=1, Tests=29,  0 wallclock secs ( 0.11 usr +  0.05 sys =  0.15 CPU)
Result: PASS
C:/jenkins/win64-2/workspace/epics-base-7.0-win64/modules/libcom/test/O.windows-x64-static
epicsUnitTestTest.tap ........ ok
epicsTypesTest.tap ........... ok
epicsInlineTest.tap .......... ok
epicsCalcTest.tap ............ ok
epicsAlgorithmTest.tap ....... ok
epicsMathTest.tap ............ ok
epicsMMIOTest.tap ............ ok
epicsEllTest.tap ............. ok
epicsEnvTest.tap ............. ok
epicsEnvUnsetTest.tap ........ ok
epicsErrlogTest.tap .......... ok
epicsStdioTest.tap ........... ok
epicsStdlibTest.tap .......... ok
epicsSockResolveTest.tap ..... ok
epicsStringTest.tap .......... ok
epicsTimeTest.tap ............ ok
epicsTimeZoneTest.tap ........ ok
epicsThreadTest.tap .......... ok
epicsThreadClassTest.tap ..... ok
epicsThreadOnceTest.tap ...... ok
epicsThreadPriorityTest.tap .. ok
epicsThreadPrivateTest.tap ... ok
epicsThreadHooksTest.tap ..... ok
epicsThreadPoolTest.tap ...... ok
epicsExitTest.tap ............ ok
epicsTimerTest.tap ........... ok
ringPointerTest.tap .......... ok
ringBytesTest.tap ............ ok
epicsEventTest.tap ........... ok
epicsMutexTest.tap ........... ok
epicsSpinTest.tap ............ ok
epicsAtomicTest.tap .......... ok
macDefExpandTest.tap ......... ok
cvtFastTest.tap .............. ok
macLibTest.tap ............... ok
aslibtest.tap ................ ok
macLib.tap ................... ok
taskwdTest.tap ............... ok
blockingSockTest.tap ......... ok
epicsMessageQueueTest.tap .... ok
epicsStackTraceTest.tap ...... ok
ipAddrToAsciiTest.tap ........ ok
osiSockTest.tap .............. ok
testexecname.tap ............. ok
iocshTest.tap ................ ok
epicsLoadTest.tap ............ ok
Test Summary Report
epicsMathTest.tap          (Wstat: 0 Tests: 35 Failed: 0)
  TODO passed:   8-9, 11-12, 22-23
epicsEventTest.tap         (Wstat: 0 Tests: 37 Failed: 0)
  TODO passed:   12-16, 18, 26, 33
Files=46, Tests=4213,  6 wallclock secs ( 0.89 usr +  0.45 sys =  1.34 CPU)
Result: PASS
C:/jenkins/win64-2/workspace/epics-base-7.0-win64/modules/database/test/ioc/db/O.windows-x64-static
dbScanTest.tap ............... ok
dbShutdownTest.tap ........... ok
dbPutLinkTest.tap ............ ok
dbLockTest.tap ............... ok
dbStressTest.tap ............. ok
testdbConvert.tap ............ ok
callbackTest.tap ............. ok
callbackParallelTest.tap ..... ok
dbStateTest.tap .............. ok
dbServerTest.tap ............. ok
dbCaStatsTest.tap ............ ok
dbCaLinkTest.tap ............. ok
scanIoTest.tap ............... ok
dbChannelTest.tap ............ ok
dbChArrTest.tap .............. ok
chfPluginTest.tap ............ ok
arrShorthandTest.tap ......... ok
recGblCheckDeadbandTest.tap .. ok
testPutGetTest.tap ........... ok
dbStaticTest.tap ............. ok
Files=20, Tests=2873,  3 wallclock secs ( 0.67 usr +  0.19 sys =  0.86 CPU)
Result: PASS
C:/jenkins/win64-2/workspace/epics-base-7.0-win64/modules/database/test/ioc/dbtemplate/O.windows-x64-static
msi.tap .. ok
Files=1, Tests=12,  0 wallclock secs ( 0.09 usr +  0.06 sys =  0.16 CPU)
Result: PASS
C:/jenkins/win64-2/workspace/epics-base-7.0-win64/modules/database/test/std/rec/O.windows-x64-static
arrayOpTest.tap ........... ok
recMiscTest.tap ........... ok
linkRetargetLinkTest.tap .. ok
linkInitTest.tap .......... ok
compressTest.tap .......... ok
asyncSoftTest.tap ......... ok
softTest.tap .............. ok
seqTest.tap ............... ok
asTest.tap ................ ok
analogMonitorTest.tap ..... ok
scanEventTest.tap ......... ok
regressTest.tap ........... ok
simmTest.tap ..............
not ok 316 - time stamp taken from second pass processing
Failed 1/1176 subtests
mbbioDirectTest.tap ....... ok
asyncproctest.tap ......... ok
netget.tap ................ ok
Test Summary Report
simmTest.tap            (Wstat: 0 Tests: 1176 Failed: 1)
  Failed test:  316
Files=16, Tests=4390,  2 wallclock secs ( 0.73 usr +  0.20 sys =  0.94 CPU)
Result: FAIL
C:/jenkins/win64-2/workspace/epics-base-7.0-win64/modules/database/test/std/link/O.windows-x64-static
lnkStateTest.tap .. ok
lnkCalcTest.tap ... ok
Files=2, Tests=58,  0 wallclock secs ( 0.11 usr +  0.06 sys =  0.17 CPU)
Result: PASS
C:/jenkins/win64-2/workspace/epics-base-7.0-win64/modules/database/test/std/filters/O.windows-x64-static
tsTest.tap .... ok
dbndTest.tap .. ok
arrTest.tap ... ok
syncTest.tap .. ok
decTest.tap ... ok
Files=5, Tests=1809,  1 wallclock secs ( 0.42 usr +  0.06 sys =  0.48 CPU)
Result: PASS
C:/jenkins/win64-2/workspace/epics-base-7.0-win64/modules/database/test/tools/O.windows-x64-static
Base.tap ........ ok
Breaktable.tap .. ok
DBD.tap ......... ok
Device.tap ...... ok
Driver.tap ...... ok
Function.tap .... ok
Menu.tap ........ ok
Recfield.tap .... ok
Recordtype.tap .. ok
Registrar.tap ... ok
Variable.tap .... ok
Files=11, Tests=293,  1 wallclock secs ( 0.17 usr +  0.14 sys =  0.31 CPU)
Result: PASS
Test failures were reported in:
make: *** [configure/RULES_TOP:54: test-results] Error 1
epics-base-7.0-win64s-test - Build # 197 - Fixed! APS Jenkins via Core-talk
Prev: Jenkins build became unstable: epics-base-7.0-win64-test #198 APS Jenkins via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to stable : epics-base-7.0-win64-test #199 APS Jenkins via Core-talk
Next: epics-base-7.0-win64s-test - Build # 197 - Fixed! APS Jenkins via Core-talk
ANJ, 20 Jul 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
