2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: AW: EPICS linker problem
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: "Zimoch Dirk (PSI)" <dirk.zimoch at psi.ch>
Cc: "'core-talk at aps.anl.gov'" <core-talk at aps.anl.gov>
Date: Thu, 16 Jul 2020 09:46:36 -0700
On 7/16/20 9:23 AM, Zimoch Dirk (PSI) wrote:
> But -rpath must contain the path at run time, which may be completely different from the -L or -rpath-link path at build time, especially for cross architectures.
I shouldn't miss such an obvious opportunity to promote
LINKER_USE_RPATH=ORIGIN as a solution to this sort of
situation.  With Base 7.0.3.1 you can have shared library
builds which don't include absolute (build host) paths
baked into the binaries.
https://sourceware.org/bugzilla/show_bug.cgi?id=20535
EPICS linker problem Zimoch Dirk (PSI) via Core-talk
Re: EPICS linker problem Michael Davidsaver via Core-talk
AW: EPICS linker problem Zimoch Dirk (PSI) via Core-talk
Prev: Re: AW: EPICS linker problem Michael Davidsaver via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: AW: EPICS linker problem Mark Rivers via Core-talk
Next: [Bug 1887981] [NEW] json parser should accept hex numbers Dirk Zimoch via Core-talk
ANJ, 19 Jul 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
