2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: epics-pva2pva-linux32 - Build # 189 - Unstable!
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sun, 26 Jul 2020 16:00:51 -0500 (CDT)
Job: <p>Build and test the EPICS v4 pva2pva module on 32-bit Linux</p>
<p>Triggered by: epics-pvAccess-linux32<br />
  Join trigger: epics-example-linux32</p>
Build URL: https://jenkins.aps.anl.gov/job/epics-pva2pva-linux32/189/
This job built successfully, but has failing tests.
Test results:
testmon.tap .. ok
All tests successful.
Files=1, Tests=79,  1 wallclock secs ( 0.12 usr +  0.02 sys =  0.14 CPU)
Result: PASS
testweak.tap ......... ok
testtest.tap ......... ok
testpvif.tap ......... ok
testpdb.tap .......... ok
testpvalink.tap ......
not ok  9 - dbGetField("src:i1.VAL", 7) -> 4 == 42
Failed 1/15 subtests
testgroupconfig.tap .. ok
testdbf_copy.tap ..... ok
Test Summary Report
testpvalink.tap    (Wstat: 0 Tests: 15 Failed: 1)
  Failed test:  9
Files=7, Tests=342,  1 wallclock secs ( 0.34 usr  0.04 sys +  0.00 cusr  0.02 csys =  0.40 CPU)
Result: FAIL
epics-pva2pva-linux32 - Build # 190 - Fixed! APS Jenkins via Core-talk
Prev: Jenkins build is back to normal : epics-7.0 » mac #242 APS Jenkins via Core-talk
Next: [Bug 1783475] Re: const link support can't handle escaped charactors Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: epics-pva2pva-linux32 - Build # 190 - Fixed! APS Jenkins via Core-talk
ANJ, 12 Aug 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
