2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1892190] Re: Building epics-base fails on musl based systems
From: Sébastien Wertz via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Thu, 20 Aug 2020 13:01:12 -0000
Thanks for the quick feedback!
>  Maybe it would be better to use uclibc instead of musl?
This is unfortunately not feasible here, when using base container
images themselves built on top of a linux distro that uses musl.
> The alternative would be to require musl users to add a line like
>    OP_SYS_CPPFLAGS += -D__MUSL__
> to their configure/os/CONFIG_SITE.Common.linux-x86_64 file before building and to use that as another input to the macros in os/posix/osdExecinfoBackTrace.cpp.
This would be entirely acceptable (provided it is documented)!
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1892190
Title:
Status in EPICS Base:
  Triaged
Bug description:
  I am trying to build EPICS base 7.0.4 inside a docker container based
  on alpine linux, which uses musl in place of glibc.
  The build options used are CXXFLAGS="-DIPPORT_USERRESERVED=5000
  -fPIC".
  The build fails because the "backtrace" function does not exist in
  musl:
  /usr/bin/g++ -o iocLogServer  -L/EPICS/base/lib/linux-x86_64 -Wl,-rpath,/EPICS/base/lib/linux-x86_64           -rdynamic -m64         iocLogServer.o    -lCom
  /usr/lib/gcc/x86_64-alpine-linux-musl/9.2.0/../../../../x86_64-alpine-linux-musl/bin/ld: /EPICS/base/lib/linux-x86_64/libCom.so: undefined reference to `backtrace'
  collect2: error: ld returned 1 exit status
  Looking into epics-
  base/modules/libcom/src/osi/os/posix/osdExecinfoBackTrace.cpp, which
  is the only file using that function, I was in the end able to
  successfully build EPICS by adding "-D__UCLIBC_MAJOR__=0" to the build
  options.
  However, it would be better to detect the presence of backtrace() by
  testing the existence of __GLIBC__ or __GNU_LIBRARY__, or,
  alternatively, to provide the user with the possibility of disabling
  backtrace support.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1892190/+subscriptions
[Bug 1892190] [NEW] Building epics-base fails on musl based systems Sébastien Wertz via Core-talk
Prev: epics-pva2pva-linux32 - Build # 192 - Still Unstable! APS Jenkins via Core-talk
Next: [Bug 1884339] Re: Inaccessible CA servers on Windows Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: [Bug 1892190] Re: Building epics-base fails on musl based systems mdavidsaver via Core-talk
Next: epics-pva2pva-linux32 - Build # 191 - Unstable! APS Jenkins via Core-talk
ANJ, 20 Aug 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
