2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Issue with caget -d 32.
From: Hugo Slepicka via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Wed, 23 Sep 2020 15:54:15 -0700
I would like to apologize as I was wrong in my statement this morning at the Core Developers meeting.
The issue with the caget -d 32 and the waveform PV was due to the wrong gateway and not when directly connected to the IOC.
After applying the patch to fix the waveforms via gateway caget started to report the proper values.
Sorry about that. It was late night and I got confused on the terminals.
I will let the gateways run a little more here at SLAC before claiming to have a fix for the gateway issue and early next week I will submit a Pull Request.
Thank you,
Hugo
Prev: Build failed: EPICS Base 7 base-7.0-88 AppVeyor via Core-talk
Next: Build completed: EPICS Base 7 base-7.0-89 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
ANJ, 25 Sep 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
