2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~freddie-akeroyd/epics-base:fix_win32_monotonic_time into epics-base:7.0
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: mp+391018 at code.launchpad.net
Date: Tue, 29 Sep 2020 16:12:03 -0000
Review: Approve
This change looks reasonable to me, and the appveyor builds succeed.  Given that this corrects a runtime bug, I think this is good enough.
The output of epicsTimeTest from one of the jobs includes:
> # Resolution 101 ns
> # epicsThreadSleep(0.0) Delta 500 ns
> # Small Delta 0 ns
I'm mildly surprised to see the Small Delta exactly zero given that this was run on a VM.  For reference, my (Linux) laptop shows
> # Resolution 1 ns
> # epicsThreadSleep(0.0) Delta 76868 ns
> # Small Delta 79 ns
I wonder about the mixing of 64-bit integer and 64-bit floating point math in epicsMonotonicGet().  (see diff comment)
Diff comments:
> diff --git a/modules/libcom/src/osi/os/WIN32/osdMonotonic.c b/modules/libcom/src/osi/os/WIN32/osdMonotonic.c
> index cb84643..208c1aa 100644
> --- a/modules/libcom/src/osi/os/WIN32/osdMonotonic.c
> +++ b/modules/libcom/src/osi/os/WIN32/osdMonotonic.c
> @@ -39,15 +42,10 @@ epicsUInt64 epicsMonotonicResolution(void)
>  epicsUInt64 epicsMonotonicGet(void)
>      LARGE_INTEGER val;
> -    if(osdUsePrefCounter) {
> -        if(!QueryPerformanceCounter(&val)) {
> -            errMessage(errlogMinor, "Warning: failed to fetch performance counter\n");
> -            return 0;
> -        } else
> -            return val.QuadPart;
> +    if(!QueryPerformanceCounter(&val)) {
> +        cantProceed("epicsMonotonicGet: Failed to read Windows Performance Counter\n");
> +        return 0;
>      } else {
> -        epicsUInt64 ret = GetTickCount();
> -        ret *= 1000000;
> -        return ret;
> +        return (epicsUInt64)(val.QuadPart * perfCounterScale + 0.5); /* return value in nanoseconds */
Since the integer value involved 64-bit, it seems like precision will eventually be lost while val.QuadPart gets high enough.  I wonder how this would manifest?  Effectively coarser resolution with longer uptime?
https://code.launchpad.net/~freddie-akeroyd/epics-base/+git/epics-base/+merge/391018
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~freddie-akeroyd/epics-base:fix_win32_monotonic_time into epics-base:7.0 Freddie Akeroyd via Core-talk
Prev: Build failed: epics-base base-fix_win32_monotonic_time-589 AppVeyor via Core-talk
Next: Re: [Merge] ~freddie-akeroyd/epics-base:fix_win32_monotonic_time into epics-base:7.0 Freddie Akeroyd via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~freddie-akeroyd/epics-base:fix_win32_monotonic_time into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 29 Sep 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
