Diff comments:
> diff --git a/modules/libcom/src/osi/os/WIN32/osdMonotonic.c b/modules/libcom/src/osi/os/WIN32/osdMonotonic.c
> index cb84643..208c1aa 100644
> --- a/modules/libcom/src/osi/os/WIN32/osdMonotonic.c
> +++ b/modules/libcom/src/osi/os/WIN32/osdMonotonic.c
> @@ -39,15 +42,10 @@ epicsUInt64 epicsMonotonicResolution(void)
> epicsUInt64 epicsMonotonicGet(void)
> LARGE_INTEGER val;
> - if(osdUsePrefCounter) {
> - if(!QueryPerformanceCounter(&val)) {
> - errMessage(errlogMinor, "Warning: failed to fetch performance counter\n");
> - return 0;
> - } else
> - return val.QuadPart;
> + if(!QueryPerformanceCounter(&val)) {
> + cantProceed("epicsMonotonicGet: Failed to read Windows Performance Counter\n");
> + return 0;
> } else {
> - epicsUInt64 ret = GetTickCount();
> - ret *= 1000000;
> - return ret;
> + return (epicsUInt64)(val.QuadPart * perfCounterScale + 0.5); /* return value in nanoseconds */
I recall that the use of nanoseconds vs. some other unit was discussed. I can't recall any details though. Knowing myself, I suspect part of my thinking was to avoid adding a set of supporting functions when operator- would do the job.
https://code.launchpad.net/~epics-core/epics-base/monotonictime/+merge/269124/comments/716066
Also, it looks like the final MR (with further discussion) for monotonictime has disappeared? I don't recall deleting this (or any) repository.
https://code.launchpad.net/~epics-core/epics-base/+git/monotonictime/+merge/331496
I don't have an objection to adding a set of functions like you describe to treat monotonic time points as (semi)opaque. It should be simple enough to keep epicsMonotonicGet() as a compatibility wrapper. This should be a separate MR though.
https://code.launchpad.net/~freddie-akeroyd/epics-base/+git/epics-base/+merge/391018
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
- [Merge] ~freddie-akeroyd/epics-base:fix_win32_monotonic_time into epics-base:7.0 Freddie Akeroyd via Core-talk
Re: [Merge] ~freddie-akeroyd/epics-base:fix_win32_monotonic_time into epics-base:7.0 Freddie Akeroyd via Core-talk
Re: [Merge] ~freddie-akeroyd/epics-base:fix_win32_monotonic_time into epics-base:7.0 mdavidsaver via Core-talk
<2020>
2025
2026
<2020>
2025
2026
