2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: [Bug 1903924] [NEW] The aao record type could use a DOL input link
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Wed, 11 Nov 2020 22:42:46 -0000
Public bug reported:
There is currently no way to copy numeric arrays between record fields
just using the core database record types. The only way I can think to
do it with any standard record type at all would be to use the aCalcout
from the synapps/calc module, but that is a rather heavy-weight
solution.
This functionality could most easily be provided by adding a DOL input
link (and a related OMSL field) to the aao record type. It should be
possible to do this in a backwards compatible way and not break existing
databases; I would want any solution offered to come with a unit test
program which demonstrates that not setting the DOL and OMSL fields
leaves the record's behavior exactly the same as it was. I suggest
writing the test before adding the new fields.
** Affects: epics-base
     Importance: Wishlist
         Status: Triaged
** Tags: codeathon
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1903924
Title:
Status in EPICS Base:
  Triaged
Bug description:
  aCalcout from the synapps/calc module, but that is a rather heavy-
  weight solution.
  existing databases; I would want any solution offered to come with a
  unit test program which demonstrates that not setting the DOL and OMSL
  fields leaves the record's behavior exactly the same as it was. I
  suggest writing the test before adding the new fields.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1903924/+subscriptions
[Bug 1903924] Re: The aao record type could use a DOL input link Dirk Zimoch via Core-talk
Prev: epics-pva2pva-linux32 - Build # 198 - Still Unstable! APS Jenkins via Core-talk
Next: [Bug 1903924] Re: The aao record type could use a DOL input link Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
ANJ, 13 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
