2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-pvAccess #733
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sat, 14 Nov 2020 16:32:46 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-pvAccess/733/display/redirect?page=changes>
Changes:
[Michael Davidsaver] Remove unused alignBuffer() and alignData()
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building on master in workspace <https://jenkins.aps.anl.gov/job/epics-pvAccess/ws/>
The recommended git tool is: NONE
No credentials specified
 > git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
 > git config remote.origin.url https://github.com/epics-base/pvAccessCPP.git # timeout=10
Cleaning workspace
 > git rev-parse --verify HEAD # timeout=10
Resetting working tree
 > git reset --hard # timeout=10
 > git clean -fdx # timeout=10
Fetching upstream changes from https://github.com/epics-base/pvAccessCPP.git
 > git --version # timeout=10
 > git --version # 'git version 1.8.3.1'
Setting http proxy: webproxy1.anl.gov:9091
 > git fetch --tags --progress https://github.com/epics-base/pvAccessCPP.git +refs/heads/*:refs/remotes/origin/* # timeout=10
 > git rev-parse refs/remotes/origin/master^{commit} # timeout=10
Checking out Revision 3b2261a61f15a3d2a46f53ca263112a4fc492d16 (refs/remotes/origin/master)
 > git config core.sparsecheckout # timeout=10
 > git checkout -f 3b2261a61f15a3d2a46f53ca263112a4fc492d16 # timeout=10
Commit message: "Remove unused alignBuffer() and alignData()"
 > git rev-list --no-walk cca473ed0ec48b9153c69bcad8a08a0dc6e49d24 # timeout=10
[Checks API] No suitable checks publisher found.
[workspace] $ /bin/sh -xe /tmp/jenkins8037567530768132027.sh
+ echo 'PVDATA = /Jenkins/jenkins/jobs/epics-pvData/workspace'
+ echo 'PVCOMMON = /Jenkins/jenkins/jobs/epics-pvCommon/workspace'
+ echo 'EPICS_BASE = /Jenkins/jenkins/jobs/epics-base-3.16/workspace'
+ make linux-x86_64
make -C ./configure linux-x86_64
make[1]: Entering directory '/Jenkins/jenkins/jobs/epics-pvAccess/workspace/configure'
perl -CSD /Jenkins/jenkins/jobs/epics-base-3.16/workspace/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-pvAccess/workspace/configure/O.linux-x86_64'
Installing CFG file ../../cfg/CONFIG_PVACCESS_VERSION
mkdir ../../cfg
Installing CFG file ../../cfg/CONFIG_PVACCESS_MODULE
perl -CSD /Jenkins/jenkins/jobs/epics-base-3.16/workspace/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-pvAccess/workspace/configure/O.linux-x86_64'
make[1]: Leaving directory '/Jenkins/jenkins/jobs/epics-pvAccess/workspace/configure'
make -C ./src linux-x86_64
make[1]: Entering directory '/Jenkins/jenkins/jobs/epics-pvAccess/workspace/src'
mkdir -p O.Common
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-pvAccess/workspace/src/O.linux-x86_64'
mkdir -p ../O.Common/pv
perl -CSD /Jenkins/jenkins/jobs/epics-base-3.16/workspace/bin/linux-x86_64/expandVars.pl -DEPICS_PVA_MAJOR_VERSION="7" -DEPICS_PVA_MINOR_VERSION="1" -DEPICS_PVA_MAINTENANCE_VERSION="3" -DEPICS_PVA_DEVELOPMENT_FLAG="1" -t ../.. -a linux-x86_64   ../pva/pvaVersionNum.h@ ../O.Common/pv/pvaVersionNum.h
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF pipelineServer.d  ../../src/pipelineService/pipelineServer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF pipelineService.d  ../../src/pipelineService/pipelineService.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF rpcClient.d  ../../src/rpcClient/rpcClient.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF rpcServer.d  ../../src/rpcService/rpcServer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF rpcService.d  ../../src/rpcService/rpcService.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF sharedstate_put.d  ../../src/server/sharedstate_put.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF sharedstate_rpc.d  ../../src/server/sharedstate_rpc.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF sharedstate_channel.d  ../../src/server/sharedstate_channel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF sharedstate_pv.d  ../../src/server/sharedstate_pv.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF server.d  ../../src/server/server.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF beaconServerStatusProvider.d  ../../src/server/beaconServerStatusProvider.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF beaconEmitter.d  ../../src/server/beaconEmitter.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF baseChannelRequester.d  ../../src/server/baseChannelRequester.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF serverChannelImpl.d  ../../src/server/serverChannelImpl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF serverContext.d  ../../src/server/serverContext.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF responseHandlers.d  ../../src/server/responseHandlers.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF clientContextImpl.d  ../../src/remoteClient/clientContextImpl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF security.d  ../../src/remote/security.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF codec.d  ../../src/remote/codec.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF serializationHelper.d  ../../src/remote/serializationHelper.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF transportRegistry.d  ../../src/remote/transportRegistry.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF blockingTCPAcceptor.d  ../../src/remote/blockingTCPAcceptor.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF abstractResponseHandler.d  ../../src/remote/abstractResponseHandler.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF channelSearchManager.d  ../../src/remote/channelSearchManager.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF blockingTCPConnector.d  ../../src/remote/blockingTCPConnector.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF beaconHandler.d  ../../src/remote/beaconHandler.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF blockingUDPConnector.d  ../../src/remote/blockingUDPConnector.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF blockingUDPTransport.d  ../../src/remote/blockingUDPTransport.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF ChannelAccessFactory.d  ../../src/factory/ChannelAccessFactory.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF clientInfo.d  ../../src/client/clientInfo.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF clientMonitor.d  ../../src/client/clientMonitor.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF clientRPC.d  ../../src/client/clientRPC.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF clientPut.d  ../../src/client/clientPut.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF clientGet.d  ../../src/client/clientGet.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF clientSync.d  ../../src/client/clientSync.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF client.d  ../../src/client/client.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF monitor.d  ../../src/client/monitor.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF pvAccess.d  ../../src/client/pvAccess.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF wildcard.d  ../../src/utils/wildcard.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF requester.d  ../../src/utils/requester.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF referenceCountingLock.d  ../../src/utils/referenceCountingLock.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF configuration.d  ../../src/utils/configuration.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF introspectionRegistry.d  ../../src/utils/introspectionRegistry.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF logger.d  ../../src/utils/logger.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF inetAddressUtil.d  ../../src/utils/inetAddressUtil.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF hexDump.d  ../../src/utils/hexDump.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF getgroups.d  ../../src/utils/getgroups.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF clientFactory.d  ../../src/pva/clientFactory.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF pvaVersion.d  ../../src/pva/pvaVersion.cpp
Installing generic include file ../../include/pv/pvaConstants.h
mkdir ../../include
mkdir ../../include/pv
Installing generic include file ../../include/pv/pvaDefs.h
Installing generic include file ../../include/pv/pvaVersion.h
Installing generated generic include file ../../include/pv/pvaVersionNum.h
Installing generic include file ../../include/pv/clientFactory.h
Installing generic include file ../../include/pv/hexDump.h
Installing generic include file ../../include/pv/logger.h
Installing generic include file ../../include/pv/introspectionRegistry.h
Installing generic include file ../../include/pv/referenceCountingLock.h
Installing generic include file ../../include/pv/configuration.h
Installing generic include file ../../include/pv/likely.h
Installing generic include file ../../include/pv/wildcard.h
Installing generic include file ../../include/pv/fairQueue.h
Installing generic include file ../../include/pv/requester.h
Installing generic include file ../../include/pv/destroyable.h
Installing generic include file ../../include/pv/monitor.h
Installing generic include file ../../include/pv/pvAccess.h
Installing generic include file ../../include/pva/client.h
mkdir ../../include/pva
Installing generic include file ../../include/pv/security.h
Installing generic include file ../../include/pv/serializationHelper.h
Installing generic include file ../../include/pv/serverContext.h
Installing generic include file ../../include/pv/beaconServerStatusProvider.h
Installing generic include file ../../include/pva/server.h
Installing generic include file ../../include/pva/sharedstate.h
Installing generic include file ../../include/pv/rpcService.h
Installing generic include file ../../include/pv/rpcServer.h
Installing generic include file ../../include/pv/rpcClient.h
Installing generic include file ../../include/pv/pipelineService.h
Installing generic include file ../../include/pv/pipelineServer.h
Installing generic include file ../../include/pv/pvAccessMB.h
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -c ../../src/pva/pvaVersion.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -c ../../src/pva/clientFactory.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -c ../../src/utils/getgroups.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -c ../../src/utils/hexDump.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -c ../../src/utils/inetAddressUtil.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -c ../../src/utils/logger.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -c ../../src/utils/introspectionRegistry.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -c ../../src/utils/configuration.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -c ../../src/utils/referenceCountingLock.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -c ../../src/utils/requester.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -c ../../src/utils/wildcard.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -c ../../src/client/pvAccess.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -c ../../src/client/monitor.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -c ../../src/client/client.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -c ../../src/client/clientSync.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -c ../../src/client/clientGet.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -c ../../src/client/clientPut.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -c ../../src/client/clientRPC.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -c ../../src/client/clientMonitor.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -c ../../src/client/clientInfo.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -c ../../src/factory/ChannelAccessFactory.cpp
In file included from ../../src/factory/ChannelAccessFactory.cpp:24:0:
../../src/remote/pv/codec.h: In static member function ‘static epics::pvAccess::detail::BlockingServerTCPTransportCodec::shared_pointer epics::pvAccess::detail::BlockingServerTCPTransportCodec::create(const shared_pointer&, SOCKET, const shared_pointer&, int, int)’:
../../src/remote/pv/codec.h:465:50: error: cannot allocate an object of abstract type ‘epics::pvAccess::detail::BlockingServerTCPTransportCodec’
                 sendBufferSize, receiveBufferSize)
../../src/remote/pv/codec.h:439:7: note:   because the following virtual functions are pure within ‘epics::pvAccess::detail::BlockingServerTCPTransportCodec’:
 class BlockingServerTCPTransportCodec :
In file included from /Jenkins/jenkins/jobs/epics-pvData/workspace/include/pv/pvIntrospect.h:23:0,
                 from /Jenkins/jenkins/jobs/epics-pvData/workspace/include/pv/pvData.h:22,
                 from ../../src/factory/ChannelAccessFactory.cpp:16:
/Jenkins/jenkins/jobs/epics-pvData/workspace/include/pv/serialize.h:108:22: note: 	virtual void epics::pvData::DeserializableControl::alignData(std::size_t)
         virtual void alignData(std::size_t alignment) =0;
/Jenkins/jenkins/jobs/epics-pvData/workspace/include/pv/serialize.h:54:22: note: 	virtual void epics::pvData::SerializableControl::alignBuffer(std::size_t)
         virtual void alignBuffer(std::size_t alignment) =0;
../../src/remote/pv/codec.h: In static member function ‘static epics::pvAccess::detail::BlockingClientTCPTransportCodec::shared_pointer epics::pvAccess::detail::BlockingClientTCPTransportCodec::create(const shared_pointer&, SOCKET, const shared_pointer&, int32_t, int32_t, const std::tr1::shared_ptr<epics::pvAccess::ClientChannelImpl>&, int8_t, float, int16_t)’:
../../src/remote/pv/codec.h:593:44: error: cannot allocate an object of abstract type ‘epics::pvAccess::detail::BlockingClientTCPTransportCodec’
                 heartbeatInterval, priority)
../../src/remote/pv/codec.h:556:7: note:   because the following virtual functions are pure within ‘epics::pvAccess::detail::BlockingClientTCPTransportCodec’:
 class BlockingClientTCPTransportCodec :
/Jenkins/jenkins/jobs/epics-base-3.16/workspace/configure/RULES_BUILD:242: recipe for target 'ChannelAccessFactory.o' failed
make[2]: *** [ChannelAccessFactory.o] Error 1
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-pvAccess/workspace/src/O.linux-x86_64'
/Jenkins/jenkins/jobs/epics-base-3.16/workspace/configure/RULES_ARCHS:62: recipe for target 'linux-x86_64' failed
make[1]: *** [linux-x86_64] Error 2
make[1]: Leaving directory '/Jenkins/jenkins/jobs/epics-pvAccess/workspace/src'
/Jenkins/jenkins/jobs/epics-base-3.16/workspace/configure/RULES_DIRS:84: recipe for target 'src.linux-x86_64' failed
make: *** [src.linux-x86_64] Error 2
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: **/O.linux-x86_64/*.tap
Did not find any matching files.
Jenkins build is back to normal : epics-pvAccess #734 APS Jenkins via Core-talk
Prev: Jenkins build is back to normal : 3.15-pvAccess-win64s #343 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-pvAccess #734 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-example-linux32 #809 APS Jenkins via Core-talk
ANJ, 14 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
