2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: Problems with hanging osiSockTest
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: "Zimoch Dirk (PSI)" <dirk.zimoch at psi.ch>
Cc: "'core-talk at aps.anl.gov'" <core-talk at aps.anl.gov>
Date: Tue, 17 Nov 2020 07:52:04 -0800
On 11/17/20 2:47 AM, Zimoch Dirk (PSI) via Core-talk wrote:
> Hello everybody,
> I have problems with a test in EPICS 7 commit 8fd36d8eef3420b42e7936e949928a6b43df7e15.
https://github.com/epics-base/epics-base/commit/8fd36d8eef3420b42e7936e949928a6b43df7e15
Isn't directly a functional change.  And the CI builds are passing.
https://travis-ci.org/github/epics-base/epics-base/builds/741084097
> osiSockTest seems to take forever.
> 'make runtests' hangs here:
> osiSockTest.t ................. 1/24
> 'make tapfiles' hangs here:
> perl -CSD osiSockTest.t -tap > osiSockTest.tap
> I am testing on RedHat 7 (linux-x86_64).
> Any ideas?
Can you check what is happening in this process?
eg. attach with gdb?
Of course, if you haven't done so already, a 'make distclean' and
rebuild would be a good place to start.
Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: Problems with hanging osiSockTest Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
ANJ, 17 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
