2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1904207] Re: softIocPVA calls iocInit unrequested and then complains
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Wed, 18 Nov 2020 23:48:25 -0000
b890d584bce92d8374ca76d09a68c49f9a8fad05 should avoid calling iocInit()
unless '-d' was explicitly passed.  This should avoid showing Dirk this
a warning.
** Also affects: epics-base/7.0
   Importance: Low
     Assignee: mdavidsaver (mdavidsaver)
       Status: New
** Changed in: epics-base/7.0
       Status: New => Fix Committed
    Milestone: None => 7.0.5
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1904207
Title:
Status in EPICS Base:
  Fix Committed
Status in EPICS Base 7.0 series:
  Fix Committed
Bug description:
  Since R7.0.4.2, softIocPVA automatically calls iocInit after reading the startup script, even if iocInit had already been called in that script. In that case it complains:
  iocBuild: IOC can only be initialized from uninitialized or stopped state
  softIoc does not do this only softIocPVA does.
  Please revert to the previous behavior which leaves the choice to the
  user if iocInit should be called or not.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1904207/+subscriptions
[Bug 1904207] [NEW] softIocPVA calls iocInit unrequested and then complains Dirk Zimoch via Core-talk
Prev: epics-7.0 - Build # 269 - Fixed! APS Jenkins via Core-talk
Next: Re: AW: Problems with hanging osiSockTest Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: [Bug 1904207] Re: softIocPVA calls iocInit unrequested and then complains mdavidsaver via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-101 AppVeyor via Core-talk
ANJ, 18 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
