2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: AW: another git question
From: "Zimoch Dirk \(PSI\) via Core-talk" <core-talk at aps.anl.gov>
To: "Yendell, Gary (DLSLtd,RAL,LSCI)" <gary.yendell at diamond.ac.uk>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Fri, 20 Nov 2020 09:09:20 +0000
Hello Gary,
Thanks for the suggestion. But I doubt that I can easily undo the whole "let's move the whole libCom directory into a completely different location" which had been done for EPICS 7.
I do not understand why git claims that the file had been deleted instead of moved. Is this how the move had been done? Delete eveything and then add everything again?  It seems so as 'git log modules/libcom/src/osi/os/posix/osdMutex.c' staryts with
commit 833648c97762c404bd44f1eddf9174cdd396dcc4
Author: Ralph Lange <ralph.lange at gmx.de>
Date:   Tue Jun 19 11:24:03 2018 +0200
    Move all under modules/libcom
No history from before the move. It seems that git has no idea that EPICS 7 modules/libcom/src/osi/os/posix/osdMutex.c has anything to do with EPICS 3 src/libCom/osi/os/posix/osdMutex.c
Another problem was that the commit contained files in libCom _and_ a file in configure so that not all paths changed the same way.
I have now applied all changes manually for each individual file. I had to modify several things anyway because of changes from EPICS 3 to 7.
Cheers,
Dirk
Von: Yendell, Gary (DLSLtd,RAL,LSCI) <gary.yendell at diamond.ac.uk>
Gesendet: Freitag, 20. November 2020 09:55
An: Zimoch Dirk (PSI) <dirk.zimoch at psi.ch>
Cc: core-talk at aps.anl.gov
Betreff: Re: another git question
Hi Dirk,
You may want to play around with the find renames option on the cherry-pick commands [1]. This adjusts the allowed % difference between two files for them to be considered renamed, rather than deleted and created.
If that doesn't work, you could
  • Rename the file to match the branch you are cherry picking from - Commit 1
  • Do the cherry-pick - Commit 2
  • Revert Commit 1 - Commit 3
  • Squash Commits 1-3
Possibly this could be scripted if it is the only thing that works and you need to do it frequently.
(Apologies if this email doesn't come through properly, I am only subscribed to core talk by RSS, so I didn't have an email to reply to.)
Cheers,
Gary
Re: another git question Ralph Lange via Core-talk
Re: another git question Yendell, Gary (DLSLtd, RAL, LSCI) via Core-talk
Prev: Re: another git question Yendell, Gary (DLSLtd, RAL, LSCI) via Core-talk
Next: Re: AW: Problems with hanging osiSockTest Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: Re: another git question Ralph Lange via Core-talk
ANJ, 20 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
