2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: mp+394327 at code.launchpad.net
Date: Mon, 23 Nov 2020 14:35:03 -0000
> ...SCHED_FIFO scheduling, which requires sufficient privileges to set. That typically means to run the IOC as root.
FWIW, IOCs should *not* be run as root.
The EPICS website has detailed instructions at
https://epics-controls.org/resources-and-support/documents/howto-documents/posix-thread-priority/
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/394327
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 23 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
