2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: mp+394327 at code.launchpad.net
Date: Tue, 24 Nov 2020 16:16:49 -0000
> ... intended for public use, which the epicsPosixMutex stuff shouldn't be ...
Ok, as internal helpers, calls like these (with an ANJ compliant name) are perfectly reasonable.  I would like to see them moved to a private header.  Maybe 'os/posix/osdMutexPvt.h'?
> ... I'm not convinced we need the env switch ...
Likewise.  We already have the build time $(USE_POSIX_THREAD_PRIORITY_SCHEDULING) switch.
> ... I'm not sure how it helps future maintainers to understand this file ...
I'll go further.  In-code comments should provide meaningful context for the code around them.  This discussion would make a nice core-talk (or maybe blog) post, but is a distraction here.
> ... I think we would probably want to delay merging this until after Heinz' RTEMS-5 code has been pulled in ...
I don't like this.  To my mind, we merge whichever is ready first, and the second needs to be reworked to resolve any conflicts.  I think this gives a health incentive for promptness.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/394327
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 24 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
