2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: mp+394327 at code.launchpad.net
Date: Fri, 27 Nov 2020 18:32:22 -0000
Also, it may be worth repeating.  Even on modern Linux, support for PTHREAD_PRIO_INHERIT can't be taken for granted as some (partially) emulated environments don't implement/allow all of the syscalls necessary for PI mutex operations.
So I think it is necessary to probe for support at runtime.  eg. with glibc, an error will be returned by pthread_mutex_init().
The obvious place to do this would be in your thread once function.  Try to create a mutex with PTHREAD_PRIO_INHERIT, the fallback to PTHREAD_PRIO_NONE if this isn't possible.  This would also help convince me that a thread once is the better approach.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/394327
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 27 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
