2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mp+394327 at code.launchpad.net
Date: Mon, 30 Nov 2020 15:39:50 -0000
I have now dropped the workaround for missing PTHREAD_MUTEX_RECURSIVE in pre 2001 Posix.
Falling back from PTHREAD_PRIO_INHERIT to PTHREAD_PRIO_NONE is still supported of course. Line 60 pthread_mutexattr_settype() will fail but that will simply result in a default mutex attribute and an error message (if errVerbose is set).
Setting PTHREAD_MUTEX_RECURSIVE in line 70 must not fail. That should not be a problem, even for rr or other special systems.
The only new external function is now called osdPosixMutexInit (not starting with "epics") and is in the private header file osdPosixMutexPriv.h which does not get installed. It is used inside libCom only.
I am not yet happy with the test. I need to find out how to use testSkip() properly when SCHED_FIFO is not available or the prority range is too limited.
There seems to be no TESTPROD_HOST_Posix (instead of TESTPROD_HOST_Linux) to run the test on all posix architectures. How to do that in the Makefile?
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/394327
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: epics-base-7.0-win64-test - Build # 237 - Unstable! APS Jenkins via Core-talk
Next: epics-base-7.0-win64-test - Build # 238 - Still Unstable! APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 18 Dec 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
