See <https://jenkins.aps.anl.gov/job/epics-base-3.15/519/display/redirect>
Changes:
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building on master in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/>
The recommended git tool is: NONE
No credentials specified
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url https://git.launchpad.net/epics-base # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base
> git --version # timeout=10
> git --version # 'git version 1.8.3.1'
Setting http proxy: webproxy1.anl.gov:9091
> git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/3.15:refs/remotes/origin/3.15 # timeout=10
ERROR: Error fetching remote repo 'origin'
hudson.plugins.git.GitException: Failed to fetch from https://git.launchpad.net/epics-base
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:1001)
at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1242)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1302)
at hudson.scm.SCM.checkout(SCM.java:505)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1206)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
at hudson.model.Run.execute(Run.java:1894)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:97)
at hudson.model.Executor.run(Executor.java:428)
Caused by: hudson.plugins.git.GitException: Command "git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/3.15:refs/remotes/origin/3.15" returned status code 128:
stdout:
stderr: fatal: Couldn't find remote ref refs/heads/3.15
Unexpected end of command stream
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2450)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:2051)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$500(CliGitAPIImpl.java:84)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:573)
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:999)
... 11 more
Archiving artifacts
- Jenkins build is back to normal : epics-base-3.15 #520 APS Jenkins via Core-talk
Build failed in Jenkins: epics-base-7.0-win64 #169 APS Jenkins via Core-talk
Build failed in Jenkins: epics-base-3.15-mac #354 APS Jenkins via Core-talk
<2020>
2025
2026
Jenkins build is back to normal : epics-base-7.0-win64 #170 APS Jenkins via Core-talk
<2020>
2025
2026
