Hi Andrew, On Wed, 23 Dec 2020 at 19:42, Johnson, Andrew N. < anj at anl.gov> wrote:
I just set “Custom
configuration .yml file
name” to empty in the epics-base-3 project UI, and it subsequently picked up and used a change I then committed to the file on the 3.15 branch! The doc’s say that the filename “.appveyor.yml”
is supported as is, and apparently leaving it blank made it do the right thing (we still have the “branches/only” whitelist in the file, I also added the regex /R3\.15\.\d+.*/ to that).
That was the original state and didn't work as expected when I tested it a few weeks ago. Note that the important point is that the epics-base-3 project should *not* build commits to the 7.0 branch and vice versa. For me, it was always all projects building all branches - unless I was using the gists.
Good luck! ~Ralph
- Re: Appveyor Settings for the 3.15 (and 7.0) branch builds Johnson, Andrew N. via Core-talk
- Appveyor Settings for the 3.15 (and 7.0) branch builds Johnson, Andrew N. via Core-talk
- Re: Appveyor Settings for the 3.15 (and 7.0) branch builds Ralph Lange via Core-talk
Jenkins build is back to normal : epics-base-7.0-win64 #170 APS Jenkins via Core-talk
Re: How to "tweak" tests? Ben Franksen via Core-talk
<2020>
2025
2026
<2020>
2025
2026
ANJ, 28 Dec 2020 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
