@mdavidsaver please comment. Is there any overlap here with RTEMS-5?
I suspect we'd want anything like this to get fixed on the 3.15 branch
as well, in which case we should target this bug to both the 3.15 and
7.0 series.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1910148
Title:
Broadcast address detection is unreliable on Linux
Status in EPICS Base:
New
Bug description:
I noticed that I have a Linux system where broadcasts are not sent to
all configured broadcast addresses. The reason is easily identified:
EPICS base still uses the SIOCGIFBRDADDR way to identify the addresses
in osiSockDiscoverBroadcastAddresses. This fails in recent systems,
when several IPs are added to one interface e.g. via "ip addr add" as
NetworkManager likes to do:
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 44:39:d4:9d:25:b6 brd ff:ff:ff:ff:ff:ff
inet 10.49.126.61/24 brd 10.49.126.255 scope global dynamic noprefixroute eno1
valid_lft 834648sec preferred_lft 834648sec
inet 10.49.125.2/24 brd 10.49.125.255 scope global eno1
valid_lft forever preferred_lft forever
In this case, only 10.49.126.255 is detected by EPICS (twice):
ifreqNext() pifreq 0x55ccbc0cc5f0, size 0x28, ifr 0x0x55ccbc0cc618
osiSockDiscoverBroadcastAddresses(): found IFACE: lo len: 0x10 current_ifreqsize: 0x28
osiSockDiscoverBroadcastAddresses(): net intf "lo" flags: 49
osiSockDiscoverBroadcastAddresses(): ignoring loopback interface: "lo"
ifreqNext() pifreq 0x55ccbc0cc618, size 0x28, ifr 0x0x55ccbc0cc640
osiSockDiscoverBroadcastAddresses(): found IFACE: eno1 len: 0x10 current_ifreqsize: 0x28
osiSockDiscoverBroadcastAddresses(): net intf "eno1" flags: 1043
found broadcast addr = a317eff
osiSockDiscoverBroadcastAddresses(): net intf "eno1" found
ifreqNext() pifreq 0x55ccbc0cc640, size 0x28, ifr 0x0x55ccbc0cc668
The workaround here would be to put the second IP on another
interface, i.e. eno1:1, but I believe the software shouldn't dictate
that.
The more modern way to identify all broadcast addresses is via
AF_NETLINK, and the code is not overly complex. I actually do have a
first patch ready, see the attachment. Obviously, this code should not
be in the generic directory, and it should probably only be selected
when #ifdef AF_NETLINK to also consider older versions of Linux (I
think kernel ≥ 2.2 (from 1999) should work, but the oldest kernel I
actually tested with the netlink code was 3.2.102). So this is just an
RFC for now. Please excuse the bad formatting. I wasn't sure if there
is a style file available for clang-format or the likes and didn't
bother to do it by hand for this first demo.
With the patch, the behavior is changed in one subtle way: Interfaces
that are down are not ignored, because this information is not
provided for RTM_GETADDR but for RTM_GETLINK. So I'd have to keep
track of which interfaces are down in between these two calls. For
other corner cases (loopback, PTP), the behavior should be identical
as explained in the code.
Obviously, osiLocalAddrOnce also still uses the old interface, but
since it should only find any address, this should be OK.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1910148/+subscriptions
- [Bug 1910148] [NEW] Broadcast address detection is unreliable on Linux Michael Ritzert via Core-talk
[Bug 1910148] Re: Broadcast address detection is unreliable on Linux mdavidsaver via Core-talk
<2021>
2025
2026
<2021>
2025
2026
