2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0
From: Ben Franksen via Core-talk <core-talk at aps.anl.gov>
To: mp+396197 at code.launchpad.net
Date: Tue, 12 Jan 2021 18:33:22 -0000
Am 12.01.21 um 19:04 schrieb Andrew Johnson:
> That test passes on the current 7.0 branch, so something in your
> refactoring may have been developed based on an assumption that
> Dirk's array code invalidated
Possibly. I vaguely remember that I had to jump through a few hoops to
get certain calls to fail on zero sized array requests, since the tests
specified it this way. I'll have to find those hoops and crawl back out...
https://code.launchpad.net/~bfrk/epics-base/+git/epics-base/+merge/396197
Your team EPICS Core Developers is requested to review the proposed merge of ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0.
Prev: Build failed in Jenkins: EPICS-3.14 #909 Jenkins EPICS PSI via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-122 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
ANJ, 12 Jan 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
