2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: EPICS-3.14 #921
From: Jenkins EPICS PSI via Core-talk <core-talk at aps.anl.gov>
To: <dirk.zimoch at psi.ch>, <core-talk at aps.anl.gov>
Date: Sun, 24 Jan 2021 19:18:28 +0100
See <http://gfa-sls2-test:8080/job/EPICS-3.14/921/display/redirect>
Started by timer
Building in workspace <http://gfa-sls2-test:8080/job/EPICS-3.14/ws/>
[WS-CLEANUP] Deleting project workspace...
[WS-CLEANUP] Deferred wipeout is used...
[WS-CLEANUP] Done
Cloning the remote Git repository
Cloning repository https://git.launchpad.net/epics-base
 > git init <http://gfa-sls2-test:8080/job/EPICS-3.14/ws/> # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base
 > git --version # timeout=10
 > git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/*:refs/remotes/origin/*
 > git config remote.origin.url https://git.launchpad.net/epics-base # timeout=10
 > git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
 > git rev-parse origin/3.14^{commit} # timeout=10
Checking out Revision 7dd1ea4cabade8c95cda5e677951e3b08f793487 (origin/3.14)
 > git config core.sparsecheckout # timeout=10
 > git checkout -f 7dd1ea4cabade8c95cda5e677951e3b08f793487
Commit message: "GNU Make 3.81 (as used on Travis) doesn't have 'undefine'"
 > git rev-list --no-walk 7dd1ea4cabade8c95cda5e677951e3b08f793487 # timeout=10
[EPICS-3.14] $ /bin/sh -xe /tmp/jenkins2274088561099474379.sh
+ tar xfz /net/gfa-fs/export/exchange/home/zimoch/epics/PSIconfig.tgz
tar (child): /net/gfa-fs/export/exchange/home/zimoch/epics/PSIconfig.tgz: Cannot open: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: EPICS-3.14 #922 Jenkins EPICS PSI via Core-talk
Build failed in Jenkins: EPICS-3.14 #920 Jenkins EPICS PSI via Core-talk
Prev: Build failed in Jenkins: EPICS-3.14 #920 Jenkins EPICS PSI via Core-talk
Next: Build failed in Jenkins: EPICS-3.14 #922 Jenkins EPICS PSI via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
ANJ, 25 Jan 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
