Am 28.01.21 um 14:20 schrieb Zimoch Dirk (PSI) via Core-talk:
> One could of course change the check to if ((prec->drvl !=0 ||
> prec->drvh !=0) && prec->drvh > prec->drvl) But then in ao as well.
> It would change traditional behavior (which used to be documented
> wrongly in earlier EPICS releases) and potentially break existing
> IOCs where people use DLRH = DRVL != 0 and expect the limits to be
> ignored. It would also introduce a new "special case" because the
> record can then be fixed to any value except 0. Another option is to
> change the defaults from 0,0 to -verybig,+verybig.
> I think a poll would be needed.
-1
This makes a bad situation worse by complicating the rules. The problem
is the use of in-band exceptional values which is bad design and will
invariably hit you back sooner or later. Better fix: add a new field to
select whether to use or ignore DRVH/L.
Cheers
Ben
signature.asc
Description: OpenPGP digital signature
- Re: A general question about convert e.g. in longout record drvh, drvl handling Ralph Lange via Core-talk
- A general question about convert e.g. in longout record drvh, drvl handling Heinz Junkes via Core-talk
- Re: A general question about convert e.g. in longout record drvh, drvl handling Heinz Junkes via Core-talk
- AW: A general question about convert e.g. in longout record drvh, drvl handling Zimoch Dirk (PSI) via Core-talk
[Bug 1913699] Re: vxWorks compilation fails with undeclared function Dirk Zimoch via Core-talk
<2021>
2025
2026
<2021>
2025
2026
