On 2021-02-04, 16:43, "Core-talk on behalf of Michael Davidsaver via Core-talk" <core-talk-bounces at aps.anl.gov on behalf of core-talk at aps.anl.gov> wrote:
> In such a tool, I would support and encourage all kinds of intelligent hints for improving databases, showing similar options for typos being the simplest example.
> (What about "Engineers that used the calcout record also often use the seq and compress records.")
> "Fixing" bugs on the fly? Rather not. Large blocks of explanations and suggestions on the IOC console? Rather not.
Fair enough. The are certainly diminishing returns for longer error messages.
There are diminishing returns for longer error messages, but it's still probably good to have more descriptive ones:
Can't set "foo.SCAN" to "10 seconds" Extraneous characters
Error at or before ")" in path "." file "badchoice.db" line 2
dbLoadRecords: failed to load 'badchoice.db'
Error: Failed to load: badchoice.db
Doesn't tell you what the problem is or how to fix it, but
Menu Choices:
"Passive"
"Event"
"I/O Intr"
"10 second"
"5 second"
"2 second"
"1 second"
".5 second"
".2 second"
".1 second"
Or some variant does. But maybe a message such as 'Can't set "foo.SCAN" to "10 seconds" - invalid menu choice' could satisfy both criteria?
Cheers,
Simon Rose
Software Engineer
European Spallation Source
- Re: CaSe-IndepeDent Menu SEARches? Michael Davidsaver via Core-talk
- CaSe-IndepeDent Menu SEARches? Johnson, Andrew N. via Core-talk
- Re: CaSe-IndepeDent Menu SEARches? Torsten Bögershausen via Core-talk
- Re: CaSe-IndepeDent Menu SEARches? Ralph Lange via Core-talk
Re: Apple Silicon (Darwin-aarch64, arm64) for EPICS base Michael Davidsaver via Core-talk
<2021>
2025
2026
<2021>
2025
2026
