2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: mp+394327 at code.launchpad.net
Date: Mon, 08 Feb 2021 17:37:32 -0000
https://github.com/mdavidsaver/epics-base/runs/1856569036?check_suite_focus=true
Progress.  Everything builds, but the new epicsMutexPriorityInversionTest fails of OSX.  Of course, it only "succeeds" on the Linux builds due to lack of permission.
I think this change is basically done and ready to go except for the new test.  Is this test so essential that it needs to be an obstacle to merging?
Maybe it would be sufficient for epicsMutexShowAll() to print a line showing if PTHREAD_PRIO_INHERIT is being set?
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/394327
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Prev: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Build failed in Jenkins: EPICS-7 #319 Jenkins EPICS PSI via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 19 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
