2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: [Bug 1896295] Re: WIN32: IOC scan loops hang
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sun, 21 Feb 2021 00:18:22 -0000
The problem of scan threads hanging was fixed by reversion of the use of
monotonic time for timers, but the underlying issue with the monotonic
time support on Windows has now been fixed by Freddie's branch.
** Changed in: epics-base
       Status: New => Fix Committed
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1896295
Title:
Status in EPICS Base:
  Fix Committed
Bug description:
  The IOC scan loops hung on all IOCs on several computers, on
  investigation this looks to be caused by the monotonic clock wrapping.
  The values of next and now in dbScan.c / periodicTask() are consistent
  with GetTickCount() wrapping (which happens every 49.7 days), which I
  believe lead to epicsEventWaitWithTimeout() being called with a large
  delay. I was initially confused by the debugger saying a delay of 0
  had been passed to epicsEventWaitWithTimeout(), but I cannot see how
  this is possible (the minimum delay should be penalty) so I assume the
  debugger is reporting incorrectly due to the code being in release
  mode.
  The epics Monotonic time functions should not normally be using
  GetTickCount(), however it looks like the logic in the test for
  whether to use GetPerformanceCounter() is inverted and so
  GetTickCount() is always used. I will push a patch to fix this, and
  also to use GetTickCount64() as a fallback instead (which wraps on a
  much longer timescale).
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1896295/+subscriptions
RE: [Bug 1896295] Re: WIN32: IOC scan loops hang Mark Rivers via Core-talk
Prev: [Merge] ~freddie-akeroyd/epics-base:fix_win32_monotonic_time into epics-base:7.0 noreply--- via Core-talk
Next: RE: [Bug 1896295] Re: WIN32: IOC scan loops hang Mark Rivers via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
ANJ, 20 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
