** Changed in: epics-base/3.15
Status: In Progress => Fix Committed
** Changed in: epics-base/7.0
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1899697
Title:
PHAS is not always respected when SCAN=Event
Status in EPICS Base:
Fix Committed
Status in EPICS Base 3.15 series:
Fix Committed
Status in EPICS Base 7.0 series:
Fix Committed
Bug description:
There is a bug when adding records to an Event scan list. Adding a
record to an event scan list with a lower PHAS than any other
previously added record will end up putting it at the *end* of the
list (not at the beginning). Triggering the bug:
$ cat test.db
record(ai, "SECOND") { field(EVNT, "E") field(SCAN, "Event") field(PHAS, "1") }
record(ai, "FIRST") { field(EVNT, "E") field(SCAN, "Event") field(PHAS, "0") }
record(ai, "THIRD") { field(EVNT, "E") field(SCAN, "Event") field(PHAS, "2") }
$ softIoc -d test.db
Starting iocInit
## EPICS R3.15.8-1+0~20200608134952.18+debian10~1.gbp3c2d35
## EPICS Base built Jun 8 2020
epics> scanpel
Event "E"
Priority Low
SECOND
FIRST
THIRD
epics>
The expected order is FIRST, SECOND, THIRD. I attached a patch (for
3.15.8) that I think fixes the issue. I found it in 3.15.8 but it
seems to affect 7.0 series as well.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1899697/+subscriptions
Build failed: EPICS Base 7 base-7.0-176 AppVeyor via Core-talk
[Bug 1783475] Re: const link support can't handle escaped charactors Andrew Johnson via Core-talk
<2021>
2025
2026
[Bug 1899697] Re: PHAS is not always respected when SCAN=Event Andrew Johnson via Core-talk
<2021>
2025
2026
