2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1904207] Re: softIocPVA calls iocInit unrequested and then complains
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 01 Mar 2021 04:22:13 -0000
** Changed in: epics-base/7.0
       Status: Fix Committed => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1904207
Title:
Status in EPICS Base:
  Fix Released
Status in EPICS Base 7.0 series:
  Fix Released
Bug description:
  Since R7.0.4.2, softIocPVA automatically calls iocInit after reading the startup script, even if iocInit had already been called in that script. In that case it complains:
  iocBuild: IOC can only be initialized from uninitialized or stopped state
  softIoc does not do this only softIocPVA does.
  Please revert to the previous behavior which leaves the choice to the
  user if iocInit should be called or not.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1904207/+subscriptions
Prev: [Bug 1908305] Re: Default DTYP can be changed by DBD file order Andrew Johnson via Core-talk
Next: [Bug 1910266] Re: FTBFS on FreeBSD 12 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: [Bug 1822028] Re: Array records: add initialization through "const" long string link Andrew Johnson via Core-talk
Next: [Bug 1881563] Re: Empty arrays have undefined behavior Andrew Johnson via Core-talk
ANJ, 28 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
