2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Zero-length array fix impact
From: Timo Korhonen via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Tue, 2 Mar 2021 08:54:37 +0000
Hello,
I would like to confirm my understanding of this issue: the 7.0.5 release notes say that “Since these changes affect the Channel Access client-side API they will require rebuilding any CA Gateways against this version or Base to properly handle zero-length arrays.”.
I assume that the gateways would still work without rebuild, but handle the zero-length arrays in the old buggy way. Which is of course not a desirable situation (behavior depends if the access was over a gateway or not) but the gateway would not crash.
Is this correct? Eventually we of course need to rebuild the CA gateways (or drop them and use only p4p.gw), this just has some potential implications on our version update planning.
Cheers,
Timo
Prev: [Bug 1913699] Re: vxWorks compilation fails with undeclared function Dirk Zimoch via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: ANN: RTEMS libnetworking relocation Chris Johns via Core-talk
Next: Re: epicsTypes.h question Johnson, Andrew N. via Core-talk
ANJ, 11 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
