2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: Re: Matlab 2020b crashes with labCA 3.7.2
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: "Johnson, Andrew N." <anj at anl.gov>, EPICS core-talk <core-talk at aps.anl.gov>
Cc: Till Straumann <till.straumann at psi.ch>
Date: Fri, 5 Mar 2021 09:44:49 -0800
On 3/5/21 9:14 AM, Johnson, Andrew N. via Core-talk wrote:
> When posix priority scheduling is enabled this gets called from inside the once() routine that the Posix epicsThreadInit() implementation runs using pthread_once(). I don’t see an easy way to avoid doing that initialization here; it might be possible by adding more lazy-init logic to only look up the min and max scheduling priorities when they are actually needed, but I suspect that would still be before the end of the initialization code.
> Hence not something we should try to fix IMHO.
Agreed.  What Till describes seems a clear bug with some wrapper
which matlab is injecting (maybe with LD_PRELOAD as well).
Re: Matlab 2020b crashes with labCA 3.7.2 Johnson, Andrew N. via Core-talk
Prev: Re: Matlab 2020b crashes with labCA 3.7.2 Johnson, Andrew N. via Core-talk
Next: Build failed in Jenkins: 3.15-pvDatabase-win64 #343 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
ANJ, 05 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
