I'm currently trying to address these kind of warnings from gcc 8:
../../../src/libCom/error/errSymLib.c:165:17: warning: ‘strncpy’ output truncated copying between 1 and 5 bytes from a string of length 15 [-Wstringop-truncation]
strncpy ( pBuf,"<err copy fail>", bufLength );
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1905159
Title:
Fix warnings from recent compiler versions
Status in EPICS Base:
Triaged
Bug description:
Builds of EPICS Base using recent versions of gcc, clang and MSVC
generate compiler warnings, which we try to minimize if possible. Some
of these warnings can be prevented with suitable code modifications,
although the code must still build on the older compilers and other
architectures that we support.
Both the 3.15 and 7.0 branches can be examined for warnings; fixes
made on the 3.15 branch get propagated to the 7.0 branch during
periodic up-merges, so there is no need to make the same changes to
both branches. Some code only exists on one branch; for example the
gdd module was unbundled after 3.15, and there are many new modules in
7.0.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1905159/+subscriptions
[Bug 1905159] Re: Fix warnings from recent compiler versions Freddie Akeroyd via Core-talk
[Bug 1182091] Re: Make TIME field directly accessible Jure Varlec via Core-talk
<2021>
2025
2026
<2021>
2025
2026
