2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1712363] Re: ao record does not support SIMM=RAW
From: Evan Daykin via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 08 Mar 2021 18:57:52 -0000
** Changed in: epics-base
     Assignee: (unassigned) => Evan Daykin (daykinev)
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1712363
Title:
Status in EPICS Base:
  Confirmed
Bug description:
  The ai record supports SIMM=RAW, where it fetches the value from
  SIOL/SVAL into RVAL and converts.
  The ao record does not support this when writing through SIOL.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1712363/+subscriptions
Prev: [Bug 1398215] Re: Make output records only write on change Andrew Johnson via Core-talk
Next: [Bug 1905159] Re: Fix warnings from recent compiler versions Freddie Akeroyd via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: [Bug 1712363] Re: ao record does not support SIMM=RAW Evan Daykin via Core-talk
ANJ, 09 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
