2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: errlog.h
From: "Pearson, Matthew R. via Core-talk" <core-talk at aps.anl.gov>
To: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
Date: Tue, 9 Mar 2021 15:20:41 +0000
I'm documenting functions in errlog.h. This may be more a doxygen question, but anyone know why doxygen would ignore certain functions that are in a header file?
There's a few functions in errloh.h that don't make it into the function list in the generated HTML file:
LIBCOM_API int errlogPrintfNoConsole(const char *pformat, ...)
    EPICS_PRINTF_STYLE(1,2);
LIBCOM_API int errlogVprintfNoConsole(const char *pformat,va_list pvar);
LIBCOM_API void errSymLookup(long status, char *pBuf, size_t bufLength);
I tried adding a doxygen comment section to one of these, but it still didn't appear.
Also, separate question... the IOC developers guide, when it describes errPrintf, has this section:
errPrintf(status, __FILE__, __LINE__,"<fmt>",...);
Where status is defined as:
0: Find latest vxWorks or Unix error.
-1: Don’t report status.
Other: See “Return Status Values”, above.
There doesn't seem to be a "Return Status Values" section as far as I can see. I've modified the doxygen comment to be the following, based on what I think it's meant to be doing:
* Where status is defined as:
 * - 0: Find latest vxWorks or Unix error.
 * - -1: Don’t report status.
 * - Other: Use this status code and lookup the string value
If that looks correct, should I also update the IOC developers guide too?
Cheers,
Matt
Re: errlog.h Johnson, Andrew N. via Core-talk
Prev: [Bug 1918275] [NEW] dbdToHtml needs better error messages Dirk Zimoch via Core-talk
Next: [Bug 1182091] Re: Make TIME field directly accessible Jure Varlec via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: [Bug 1918275] Re: dbdToHtml needs better error messages Dirk Zimoch via Core-talk
Next: Re: errlog.h Johnson, Andrew N. via Core-talk
ANJ, 12 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
