There are some warnings from gcc 8.3.0 (and above) on biRecord.c and on
boRecord.c similar to this one (from 3.15 branch):
../../../src/std/rec/biRecord.c: In function ‘get_enum_str’:
../../../src/std/rec/biRecord.c:165:35: warning: argument to ‘sizeof’ in ‘strncpy’ call is the same expression as the source; did you mean to use the size of the destination? [-Wsizeof-pointer-memaccess]
strncpy(pstring,prec->znam,sizeof(prec->znam));
I think it looks a place where a problem could occur if the size of znam is greater than pstring. If we are sure this is not an issue, we could solve the warning using a fixed length (on the biRecord and boRecord case, znam and onam have length 26).
On that case, could make sense to have a constant for onam, znam (and others similar) length.
Does it make sense?
Any other suggestion ?
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1905159
Title:
Fix warnings from recent compiler versions
Status in EPICS Base:
Triaged
Bug description:
Builds of EPICS Base using recent versions of gcc, clang and MSVC
generate compiler warnings, which we try to minimize if possible. Some
of these warnings can be prevented with suitable code modifications,
although the code must still build on the older compilers and other
architectures that we support.
Both the 3.15 and 7.0 branches can be examined for warnings; fixes
made on the 3.15 branch get propagated to the 7.0 branch during
periodic up-merges, so there is no need to make the same changes to
both branches. Some code only exists on one branch; for example the
gdd module was unbundled after 3.15, and there are many new modules in
7.0.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1905159/+subscriptions
Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Dirk Zimoch via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Ben Franksen via Core-talk
<2021>
2025
2026
[Bug 1905159] Re: Fix warnings from recent compiler versions Andrew Johnson via Core-talk
[Bug 1905159] Re: Fix warnings from recent compiler versions Gabriel Fedel via Core-talk
<2021>
2025
2026
