2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: epics-pva2pva-linux32 - Build # 217 - Unstable!
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 12 Mar 2021 12:30:20 -0600 (CST)
Build and test the EPICS v4 pva2pva module on 32-bit Linux
Triggered by: epics-pvAccess-linux32
Join trigger: epics-example-linux32
Build URL: https://jenkins.aps.anl.gov/job/epics-pva2pva-linux32/217/
This job built successfully, but has failing tests.
Test results:
testmon.tap .. ok
All tests successful.
Files=1, Tests=79,  0 wallclock secs ( 0.08 usr +  0.01 sys =  0.09 CPU)
Result: PASS
testweak.tap ......... ok
testtest.tap ......... ok
testpvif.tap .........
Failed 1/92 subtests
	(less 3 skipped subtests: 88 okay)
testpdb.tap .......... ok
testpvalink.tap ...... ok
testgroupconfig.tap .. ok
testdbf_copy.tap ..... ok
Test Summary Report
testpvif.tap       (Wstat: 0 Tests: 91 Failed: 0)
  Parse errors: Bad plan.  You planned 92 tests but ran 91.
Files=7, Tests=345,  1 wallclock secs ( 0.20 usr  0.03 sys +  0.00 cusr  0.02 csys =  0.25 CPU)
Result: FAIL
epics-pva2pva-linux32 - Build # 218 - Still Unstable! APS Jenkins via Core-talk
Prev: Jenkins build became unstable: epics-pva2pva-mac #315 APS Jenkins via Core-talk
Next: Build failed: pva2pva 1.0.22 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Jenkins build is back to stable : epics-pva2pva-mac #316 APS Jenkins via Core-talk
Next: epics-pva2pva-linux32 - Build # 218 - Still Unstable! APS Jenkins via Core-talk
ANJ, 12 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
