2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: IPv6
From: "Shen, Guobao via Core-talk" <core-talk at aps.anl.gov>
To: "Hu, Yong" <yhu at bnl.gov>, Ben Franksen <benjamin.franksen at helmholtz-berlin.de>, "Zimoch Dirk (PSI)" <dirk.zimoch at psi.ch>, "Johnson, Andrew N." <anj at anl.gov>, "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Tue, 16 Mar 2021 17:41:44 +0000
A positive motivation which we may take away from this is to make EPICS IPv6 compatible and ready if we can get it funded properly.
Guobao
On 3/16/21, 8:58 AM, "Core-talk on behalf of Hu, Yong via Core-talk" <core-talk-bounces at aps.anl.gov on behalf of core-talk at aps.anl.gov> wrote:
    The problem was discussed on Tech-Talk last year: https://epics.anl.gov/tech-talk/2020/msg01939.php
    BTW, the Whitehouse Memo was issued last November and there is a new administration in the U.S. right now. It will be interesting to see an update on IPv6 from the new administration.
    On 3/16/21, 5:32 AM, "Core-talk on behalf of Ben Franksen via Core-talk" <core-talk-bounces at aps.anl.gov on behalf of core-talk at aps.anl.gov> wrote:
        Am 16.03.21 um 09:44 schrieb Zimoch Dirk (PSI) via Core-talk:
        > On Fri, 2021-03-12 at 03:34 +0000, Johnson, Andrew N. via Core-talk wrote:
        >> https://www.whitehouse.gov/wp-content/uploads/2020/11/M-21-07.pdf
        >> - Andrew
        > TL;DR
        > Do we have a problem?
        I may be wrong, but AFAIU only facilities in the US have a problem. They
        need to convince their over-bosses that they get an exception.
        Cheers
        Ben
        I would rather have questions that cannot be answered, than answers that
        cannot be questioned.  -- Richard Feynman
IPv6 Johnson, Andrew N. via Core-talk
Re: IPv6 Zimoch Dirk (PSI) via Core-talk
Re: IPv6 Ben Franksen via Core-talk
Re: IPv6 Hu, Yong via Core-talk
Prev: Re: IPv6 Hu, Yong via Core-talk
Next: Build completed: EPICS Base 7 base-7.0-251 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: IPv6 Johnson, Andrew N. via Core-talk
ANJ, 16 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
