2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Re: IPv6
From: "Kasemir, Kay via Core-talk" <core-talk at aps.anl.gov>
To: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Tue, 16 Mar 2021 19:27:58 +0000
> Personally, I see IPv6 as one of several "modernization" requirements
In principle, the PVAccess protocol is prepared for IPv6.
For example, search replies have room for v6 addresses.
When I worked on the updated Java lib, I found a few places in the original Java code which comments like "current use of multicast addresses works only with INET, not INET6".
So the channel for the UDP port is opened for INET, not INET6 protocol.
But I've never tried it with INET6, no idea what the specific issues would be.
Does anybody know?
Would an effort to support IPv6 consider updating Channel Access, or would we concentrate on PVAccess?
-Kay
Re: [EXTERNAL] Re: IPv6 Michael Davidsaver via Core-talk
IPv6 Johnson, Andrew N. via Core-talk
Re: IPv6 Zimoch Dirk (PSI) via Core-talk
Re: IPv6 Ben Franksen via Core-talk
Re: IPv6 Johnson, Andrew N. via Core-talk
Prev: Re: IPv6 Michael Davidsaver via Core-talk
Next: RE: IPv6 Mark Rivers via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: [EXTERNAL] Re: IPv6 Michael Davidsaver via Core-talk
ANJ, 16 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
