See <https://jenkins.aps.anl.gov/job/epics-example/714/display/redirect>
Changes:
Started by upstream project "epics-pvDatabase-vx68" build number 583
originally caused by:
Started by upstream project "epics-pvDatabase" build number 616
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building on master in workspace <https://jenkins.aps.anl.gov/job/epics-example/ws/>
The recommended git tool is: NONE
No credentials specified
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url https://github.com/epics-base/exampleCPP.git # timeout=10
Cleaning workspace
> git rev-parse --verify HEAD # timeout=10
Resetting working tree
> git reset --hard # timeout=10
> git clean -fdx # timeout=10
Fetching upstream changes from https://github.com/epics-base/exampleCPP.git
> git --version # timeout=10
> git --version # 'git version 1.8.3.1'
Setting http proxy: webproxy1.anl.gov:9091
> git fetch --tags --progress https://github.com/epics-base/exampleCPP.git +refs/heads/*:refs/remotes/origin/* # timeout=10
> git rev-parse refs/remotes/origin/master^{commit} # timeout=10
Checking out Revision 3d888491c114cd313bdb28c4aabf85a6054249e7 (refs/remotes/origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f 3d888491c114cd313bdb28c4aabf85a6054249e7 # timeout=10
Commit message: "Merge pull request #60 from epics-base/access-security"
> git rev-list --no-walk 3d888491c114cd313bdb28c4aabf85a6054249e7 # timeout=10
[workspace] $ /bin/sh -xe /tmp/jenkins3663221088671798232.sh
+ echo 'PVDATABASE = /Jenkins/jenkins/jobs/epics-pvDatabase/workspace'
+ echo 'PVACLIENT = /Jenkins/jenkins/jobs/epics-pvaClient/workspace'
+ echo 'PVA2PVA = /Jenkins/jenkins/jobs/epics-pva2pva/workspace'
+ echo 'PVACCESS = /Jenkins/jenkins/jobs/epics-pvAccess/workspace'
+ echo 'NORMATIVE = /Jenkins/jenkins/jobs/epics-normativeTypes/workspace'
+ echo 'PVDATA = /Jenkins/jenkins/jobs/epics-pvData/workspace'
+ echo 'PVCOMMON = /Jenkins/jenkins/jobs/epics-pvCommon/workspace'
+ echo 'EPICS_BASE = /Jenkins/jenkins/jobs/epics-base-3.16/workspace'
+ make host
make -C ./configure install.linux-x86_64
make[1]: Entering directory '/Jenkins/jenkins/jobs/epics-example/workspace/configure'
perl -CSD /Jenkins/jenkins/jobs/epics-base-3.16/workspace/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
perl -CSD /Jenkins/jenkins/jobs/epics-base-3.16/workspace/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32 ../..
perl -CSD /Jenkins/jenkins/jobs/epics-base-3.16/workspace/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32sf ../..
perl -CSD /Jenkins/jenkins/jobs/epics-base-3.16/workspace/bin/linux-x86_64/makeMakefile.pl O.RTEMS-uC5282 ../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
T_A=linux-x86_64 install
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-example/workspace/configure/O.linux-x86_64'
perl -CSD /Jenkins/jenkins/jobs/epics-base-3.16/workspace/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-example/workspace/configure/O.linux-x86_64'
make[1]: Leaving directory '/Jenkins/jenkins/jobs/epics-example/workspace/configure'
make -C ./database install.linux-x86_64
make[1]: Entering directory '/Jenkins/jenkins/jobs/epics-example/workspace/database'
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-example/workspace/database/configure'
mkdir -p O.Common
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-example/workspace/database/configure/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-example/workspace/database/configure/O.linux-x86_64'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-example/workspace/database/configure'
make -C ./src install.linux-x86_64
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-example/workspace/database/src'
mkdir -p O.Common
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-example/workspace/database/src/O.linux-x86_64'
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvDatabase/workspace/include -I/Jenkins/jenkins/jobs/epics-pvaClient/workspace/include -I/Jenkins/jenkins/jobs/epics-pva2pva/workspace/include -I/Jenkins/jenkins/jobs/epics-pvAccess/workspace/include -I/Jenkins/jenkins/jobs/epics-normativeTypes/workspace/include -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF exampleHelloRPCClient.d ../exampleHelloRPCClient.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvDatabase/workspace/include -I/Jenkins/jenkins/jobs/epics-pvaClient/workspace/include -I/Jenkins/jenkins/jobs/epics-pva2pva/workspace/include -I/Jenkins/jenkins/jobs/epics-pvAccess/workspace/include -I/Jenkins/jenkins/jobs/epics-normativeTypes/workspace/include -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF exampleDatabaseMain.d ../exampleDatabaseMain.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvDatabase/workspace/include -I/Jenkins/jenkins/jobs/epics-pvaClient/workspace/include -I/Jenkins/jenkins/jobs/epics-pva2pva/workspace/include -I/Jenkins/jenkins/jobs/epics-pvAccess/workspace/include -I/Jenkins/jenkins/jobs/epics-normativeTypes/workspace/include -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF exampleSoftRecordRegister.d ../exampleSoftRecordRegister.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvDatabase/workspace/include -I/Jenkins/jenkins/jobs/epics-pvaClient/workspace/include -I/Jenkins/jenkins/jobs/epics-pva2pva/workspace/include -I/Jenkins/jenkins/jobs/epics-pvAccess/workspace/include -I/Jenkins/jenkins/jobs/epics-normativeTypes/workspace/include -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF exampleDatabaseRegister.d ../exampleDatabaseRegister.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvDatabase/workspace/include -I/Jenkins/jenkins/jobs/epics-pvaClient/workspace/include -I/Jenkins/jenkins/jobs/epics-pva2pva/workspace/include -I/Jenkins/jenkins/jobs/epics-pvAccess/workspace/include -I/Jenkins/jenkins/jobs/epics-normativeTypes/workspace/include -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF exampleDatabase.d ../exampleDatabase.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvDatabase/workspace/include -I/Jenkins/jenkins/jobs/epics-pvaClient/workspace/include -I/Jenkins/jenkins/jobs/epics-pva2pva/workspace/include -I/Jenkins/jenkins/jobs/epics-pvAccess/workspace/include -I/Jenkins/jenkins/jobs/epics-normativeTypes/workspace/include -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF exampleHelloRPCRecord.d ../exampleHelloRPCRecord.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvDatabase/workspace/include -I/Jenkins/jenkins/jobs/epics-pvaClient/workspace/include -I/Jenkins/jenkins/jobs/epics-pva2pva/workspace/include -I/Jenkins/jenkins/jobs/epics-pvAccess/workspace/include -I/Jenkins/jenkins/jobs/epics-normativeTypes/workspace/include -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF exampleSoftRecord.d ../exampleSoftRecord.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvDatabase/workspace/include -I/Jenkins/jenkins/jobs/epics-pvaClient/workspace/include -I/Jenkins/jenkins/jobs/epics-pva2pva/workspace/include -I/Jenkins/jenkins/jobs/epics-pvAccess/workspace/include -I/Jenkins/jenkins/jobs/epics-normativeTypes/workspace/include -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF exampleHelloRecord.d ../exampleHelloRecord.cpp
Installing dbd file ../../dbd/exampleDatabaseRegister.dbd
mkdir ../../dbd
Installing dbd file ../../dbd/exampleSoftRecordRegister.dbd
Installing generic include file ../../include/pv/exampleHelloRecord.h
mkdir ../../include
mkdir ../../include/pv
Installing generic include file ../../include/pv/exampleHelloRPCRecord.h
Installing generic include file ../../include/pv/exampleSoftRecord.h
Installing generic include file ../../include/pv/exampleDatabase.h
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvDatabase/workspace/include -I/Jenkins/jenkins/jobs/epics-pvaClient/workspace/include -I/Jenkins/jenkins/jobs/epics-pva2pva/workspace/include -I/Jenkins/jenkins/jobs/epics-pvAccess/workspace/include -I/Jenkins/jenkins/jobs/epics-normativeTypes/workspace/include -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../exampleHelloRecord.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvDatabase/workspace/include -I/Jenkins/jenkins/jobs/epics-pvaClient/workspace/include -I/Jenkins/jenkins/jobs/epics-pva2pva/workspace/include -I/Jenkins/jenkins/jobs/epics-pvAccess/workspace/include -I/Jenkins/jenkins/jobs/epics-normativeTypes/workspace/include -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../exampleSoftRecord.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvDatabase/workspace/include -I/Jenkins/jenkins/jobs/epics-pvaClient/workspace/include -I/Jenkins/jenkins/jobs/epics-pva2pva/workspace/include -I/Jenkins/jenkins/jobs/epics-pvAccess/workspace/include -I/Jenkins/jenkins/jobs/epics-normativeTypes/workspace/include -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../exampleHelloRPCRecord.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvDatabase/workspace/include -I/Jenkins/jenkins/jobs/epics-pvaClient/workspace/include -I/Jenkins/jenkins/jobs/epics-pva2pva/workspace/include -I/Jenkins/jenkins/jobs/epics-pvAccess/workspace/include -I/Jenkins/jenkins/jobs/epics-normativeTypes/workspace/include -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../exampleDatabase.cpp
../exampleDatabase.cpp:21:28: fatal error: pv/traceRecord.h: No such file or directory
#include <pv/traceRecord.h>
compilation terminated.
/Jenkins/jenkins/jobs/epics-base-3.16/workspace/configure/RULES_BUILD:242: recipe for target 'exampleDatabase.o' failed
make[3]: *** [exampleDatabase.o] Error 1
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-example/workspace/database/src/O.linux-x86_64'
/Jenkins/jenkins/jobs/epics-base-3.16/workspace/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-example/workspace/database/src'
/Jenkins/jenkins/jobs/epics-base-3.16/workspace/configure/RULES_DIRS:84: recipe for target 'src.install.linux-x86_64' failed
make[1]: *** [src.install.linux-x86_64] Error 2
make[1]: Leaving directory '/Jenkins/jenkins/jobs/epics-example/workspace/database'
/Jenkins/jenkins/jobs/epics-base-3.16/workspace/configure/RULES_DIRS:84: recipe for target 'database.install.linux-x86_64' failed
make: *** [database.install.linux-x86_64] Error 2
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: test/O.*/*.tap
Did not find any matching files.
- Jenkins build is back to normal : epics-example #715 APS Jenkins via Core-talk
Build failed in Jenkins: epics-example-linux32 #852 APS Jenkins via Core-talk
Build failed in Jenkins: epics-pvDatabase-win64 #886 APS Jenkins via Core-talk
<2021>
2025
2026
Jenkins build is back to normal : epics-example-linux32 #853 APS Jenkins via Core-talk
<2021>
2025
2026
