Today I pushed a merge request which caused several tests to fail at locations which are unrelated to my change.
https://github.com/dirk-zimoch/epics-base/actions/runs/754804587
Is there something wrong with the test setup? Is the current 7.0 head OK?
I don't see any failing tests there - what are you referring to?
Cheers, ~Ralph
- Re: failing tests on github.com Torsten Bögershausen via Core-talk
- failing tests on github.com Zimoch Dirk (PSI) via Core-talk
AW: failing tests on github.com Zimoch Dirk (PSI) via Core-talk
<2021>
2025
2026
Re: failing tests on github.com Michael Davidsaver via Core-talk
<2021>
2025
2026
ANJ, 20 Apr 2021 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
