2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: Re: failing tests on github.com
From: "J. Lewis Muir via Core-talk" <core-talk at aps.anl.gov>
To: "Zimoch Dirk (PSI)" <dirk.zimoch at psi.ch>
Cc: "'core-talk at aps.anl.gov'" <core-talk at aps.anl.gov>
Date: Fri, 16 Apr 2021 10:04:55 -0500
On 04/16, Zimoch Dirk (PSI) via Core-talk wrote:
> "Tests that are regularly failing" are worse than useless. How am I supposed to find out if I broke something if there are testes that "fail normally"? If they cannot be fixed, they should be removed or at least disabled.
+1.  Absolutely "worse than useless."
Lewis
failing tests on github.com Zimoch Dirk (PSI) via Core-talk
Re: failing tests on github.com Ben Franksen via Core-talk
AW: failing tests on github.com Zimoch Dirk (PSI) via Core-talk
Prev: Re: failing tests on github.com Ralph Lange via Core-talk
Next: Re: failing tests on github.com Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: AW: failing tests on github.com Zimoch Dirk (PSI) via Core-talk
ANJ, 16 Apr 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
