2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: RE: Problem building NDPluginPVA on base 7.0.5
From: Mark Rivers via Core-talk <core-talk at aps.anl.gov>
To: 'EPICS core-talk' <core-talk at aps.anl.gov>
Date: Wed, 28 Apr 2021 21:28:46 +0000
I answered my own question.
NDPluginBadPixel_CXXFLAGS_Linux += -std=c++11
Just uses that flag for a single file and fixes my problem.
I am curious if what I observed is expected though, i.e. base needs to be compiled with that flag if NDPluginPva is.
Sent: Wednesday, April 28, 2021 4:21 PM
To: EPICS core-talk <core-talk at aps.anl.gov>
Subject: Problem building NDPluginPVA on base 7.0.5
I ran into a problem today.  I changed the areaDetector/ADCore/ADApp/pluginSrc/Makefile to add this line because I need it for a new plugin:
USR_CXXFLAGS_Linux += -std=c++11
The new plugin works, but now I get the following error when I link any areaDetector IOC:
/home/epics/devel/areaDetector-3-10/ADSupport/supportApp/GraphicsMagickSrc/jp2/src/libjasper/O.linux-x86_64/../../../../../../supportApp/GraphicsMagickSrc/jp2/src/libjasper/base/jas_stream.c:368: warning: the use of `tmpnam' is dangerous, better use `mkstemp'
/home/epics/devel/areaDetector-3-10/ADCore/lib/linux-x86_64/libNDPlugin.a(NDPluginPva.o): In function `NTNDArrayRecord':
/home/epics/devel/areaDetector-3-10/ADCore/ADApp/pluginSrc/O.linux-x86_64/../NDPluginPva.cpp:32: undefined reference to `epics::pvDatabase::PVRecord::PVRecord(std::string const&, std::shared_ptr<epics::pvData::PVStructure> const&)'
/home/epics/devel/areaDetector-3-10/ADCore/lib/linux-x86_64/libNDPlugin.a(NDPluginPva.o): In function `NDPluginPva::NDPluginPva(char const*, int, int, char const*, int, char const*, int, unsigned long, int, int)':
/home/epics/devel/areaDetector-3-10/ADCore/ADApp/pluginSrc/O.linux-x86_64/../NDPluginPva.cpp:177: undefined reference to `epics::pvDatabase::PVDatabase::addRecord(std::shared_ptr<epics::pvDatabase::PVRecord> const&)'
/home/epics/devel/areaDetector-3-10/ADCore/lib/linux-x86_64/libNDPlugin.a(NDPluginPva.o): In function `NTNDArrayRecord::init()':
/home/epics/devel/areaDetector-3-10/ADCore/ADApp/pluginSrc/O.linux-x86_64/../NDPluginPva.cpp:64: undefined reference to `epics::nt::NTNDArray::wrap(std::shared_ptr<epics::pvData::PVStructure> const&)'
/home/epics/devel/areaDetector-3-10/ADCore/ADApp/pluginSrc/O.linux-x86_64/../NDPluginPva.cpp:65: undefined reference to `NTNDArrayConverter::NTNDArrayConverter(std::shared_ptr<epics::nt::NTNDArray>)'
/home/epics/devel/areaDetector-3-10/ADCore/lib/linux-x86_64/libNDPlugin.a(NDPluginPva.o):(.data.rel.ro._ZTV15NTNDArrayRecord[_ZTV15NTNDArrayRecord]+0x20): undefined reference to `epics::pvDatabase::PVRecord::nextMasterPVField(std::shared_ptr<epics::pvData::PVField> const&)'
collect2: error: ld returned 1 exit status
I am running base 7.0.5.
Is this because if I build NDPluginPVA with the c++11 flag I also need to build base with the same flag?
Can I tell the EPICS build system to only compile my new plugin with that flag, and not all files in the pluginSrc directory?
Problem building NDPluginPVA on base 7.0.5 Mark Rivers via Core-talk
Prev: Problem building NDPluginPVA on base 7.0.5 Mark Rivers via Core-talk
Next: Re: Problem building NDPluginPVA on base 7.0.5 Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
ANJ, 28 Apr 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
